Re: 97 5.2 trouble
[Re: Dabee]
#2029963
03/12/16 09:53 PM
03/12/16 09:53 PM
Posts: 12,422 Kalispell Mt.
HotRodDave
Kalispell Mt.
Bet its a MAP sensor, I had a 97 1500 5.2 4x4 in the shop yesterday did exactly like you describe, engine vacuume and atmosphere were reading the same, threw one on out of my parts pile and it ran like new. I think that was the first time I seen a bad MAP on a magnum engine.
Re: 97 5.2 trouble
[Re: HotRodDave]
#2029984
03/12/16 10:28 PM
03/12/16 10:28 PM
Posts: 3,458 Dandridge TN
Dabee
Dandridge TN
Bet its a MAP sensor, I had a 97 1500 5.2 4x4 in the shop yesterday did exactly like you describe, engine vacuume and atmosphere were reading the same, threw one on out of my parts pile and it ran like new. I think that was the first time I seen a bad MAP on a magnum engine. Thanks, I have a low milage 5.9 setting in the shop. When I get back home next week I'll swap the MAP out of the 5.9 and see what happens.
Re: 97 5.2 trouble
[Re: Dabee]
#2030030
03/13/16 12:21 AM
03/13/16 12:21 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
What codes are being thrown?
Doesn't make any sense to throw parts at it without looking at what the computer is telling you.
Re: 97 5.2 trouble
[Re: Supercuda]
#2030062
03/13/16 01:35 AM
03/13/16 01:35 AM
Dabee
Dandridge TN
Doesn't make any sense to throw parts at it without looking at what the computer is telling you. The only code its throwing is battery temp sensor voltage to high. That can be fixed by changing the diode, which we will do to turn off the check engine light. Parts aren't a problem. I have another engine in the shop I can get parts off of, plus a buddy that works in a salvage yard that can get me no cost parts to troubleshoot with.
Re: 97 5.2 trouble
[Re: Dabee]
#2030064
03/13/16 01:40 AM
03/13/16 01:40 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
Make sure the dist is indexed right. Of course the dist does not set timing as its basically a cam sensor on that eng but it has to be indexed to the crank sensor as I had some that would run bad above about 2 to 3000 rpm when the dist was out of index a bit. You can check it either with a digital voltmeter or a scan tool if your scan tool has that function. Good luck with it. I am guessing its still charging ok as the PCM should use a limp figure for battery temp with that code set as normally the higher the temp the PCM see's from the battery temp sensor the lower the target charging volts ? Ron
Re: 97 5.2 trouble update
[Re: 383man]
#2030092
03/13/16 02:28 AM
03/13/16 02:28 AM
Dabee
Dandridge TN
Ron, thanks I think you may have hit on the problem. Never having worked with these engines I'm learning as I go here. I just finished researching dist sync and it sounds like the problem my engine is exhibiting. I'll check the sync before I do anything else.
