Who is running cat converters? #2029413
03/11/16 09:05 PM
03/11/16 09:05 PM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
Im considering installing them just to kill the awful smell pump gas makes these days. I even get around my car after its been run and i can smell the fumes on me. And no its not an overly rich condition. smile Anyone run the 3" cats and did they kill a lot of power?
Re: Who is running cat converters? [Re: Hot 340] #2029437
03/11/16 10:04 PM
03/11/16 10:04 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
If it is not running that rich, it shouldn't smell that bad? Cats aren't going to 'fix' the issues it sounds like really. Sounds like the car has other issues perhaps... (I have a friend with a couple of carb'd cars still both with larger cams, aftermarket most things, stroker engines, etc and no smells out of them really.
And I have a modern engine swap in my car and don't run cats (I have the rear O2 sensors tuned out)...can't see a reason to run an exhaust restriction if not needed..
Re: Who is running cat converters? [Re: Hot 340] #2029442
03/11/16 10:15 PM
03/11/16 10:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If you can smell it then it's running rich. The new gas doesn't smell any more than the old stuff if the car is tuned right.
Re: Who is running cat converters? [Re: stumpy] #2029568
03/12/16 01:05 AM
03/12/16 01:05 AM
IN
ahy Offline
ahy  Offline
IN
If its running rich... or slightly different situation you have some air fuel charge running through the engine at low RPM due to a high overlap cam, the cats won't like it. They will try to "burn" it, then overheat, then plug up and fail. Hopefully not cause a fire in the process.
With a high overlap cam, ignition timing helps clean up the idle. 20 degrees as a ballpark. With timing set, carb tuning helps. Still, there may be some smell. I have it with a 243 degree @.050 cam. Nature of the beast. Probably not an issue with intake duration of ~220 degrees or less.
Re: Who is running cat converters? [Re: Hot 340] #2029574
03/12/16 01:19 AM
03/12/16 01:19 AM
jersey
Spaceman Spiff Offline
jersey
what's the combination, and how do you know it's not a rich condition? have you check using a gas analyzer?
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Who is running cat converters? [Re: ahy] #2029596
03/12/16 01:52 AM
03/12/16 01:52 AM
Pa
Hot 340 Offline OP
Hot 340  Offline OP
Pa
I hear ya. Mine is a custom Bullet cam with 255@ .050. I have a custom carb that will do anything i want it to as far a getting rid of a rich condition. It reeks ( more or less)no matter where i put it. My last car was a 5.0 mustang with fuel injection. With the cats you could stand behind the car all day. With the cats off via off road h pipe it would still gag ya, and it was clean burning.
Re: Who is running cat converters? [Re: Hot 340] #2029606
03/12/16 02:08 AM
03/12/16 02:08 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
That is a pretty different animal. You are comparing a mild cammed, fuel injected, computer controlled catalyst setup to a big cam carbureted car.
Re: Who is running cat converters? [Re: Hot 340] #2029661
03/12/16 04:32 AM
03/12/16 04:32 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
For sure. My stock 360 Magnum EFI without a cat and it stinks too. Everything from my 1 bbl to 6 bbl make your eyes water.
But, (quote from an online SRT Engineer session) converters cost 25 hp.
I've also noticed that alot of the older engines left in production with converters (like the Magnums) crack heads. I've even run into a fellow that had it happen on a 5.7 hemi. twocents
Your best option is to run leaded fuel, that's what I do.
Mo' Farts
Moderated by "tbagger".
Re: Who is running cat converters? [Re: Hot 340] #2029800
03/12/16 03:04 PM
03/12/16 03:04 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
If you can smell fumes on you, you've got tune issues. Its not the gas.
