4.7 Jeep starter help. How to jump this starter? #202931
01/24/09 03:11 PM
01/24/09 03:11 PM
Tri-Cities, Washington
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
Wife's '04 Grand Cherokee won't start. Lights, etc work, don't dim. Battery is good but the starter "clicks". How do I jump the starter to see if it's working properly. I see that there are two post and one small wire on a clip. I turned the key to "run" and bridged the two posts and nothing what so ever (no click, etc). What am I doing wrong?
Re: 4.7 Jeep starter help. How to jump this starter? [Re: VITC_GTX] #202932
01/24/09 06:07 PM
01/24/09 06:07 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
Have your wife turn the key to start while you crawl underneath and tap the starter with a hammer. It should fire right up. It will possibly work a few times after that as well, but don't trust it for too long. Replace it asap.
Re: 4.7 Jeep starter help. How to jump this starter? [Re: VITC_GTX] #202933
01/24/09 09:40 PM
01/24/09 09:40 PM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
I beat the heck out of it but no-go. Ended up being a bad connection. Took the starter out and it tested fine. Cleaned everything up and it starts just fine now.
Thanks for the help.
Re: 4.7 Jeep starter help. How to jump this starter? [Re: VITC_GTX] #202934
01/25/09 01:23 AM
01/25/09 01:23 AM
Southeast Pa.
SALEM1912 Offline
SALEM1912  Offline
Southeast Pa.
Was it one click or several clicks? One click is a bad starter, several clicks would be low battery voltage. BTW last 4.7 starter I put in was only $78. list at dealer. They do go bad a lot.
Re: 4.7 Jeep starter help. How to jump this starter? [Re: SALEM1912] #202935
01/25/09 01:25 AM
01/25/09 01:25 AM
V
VITC_GTX Offline OP
VITC_GTX  Offline OP
V
One click. Luckily I didn't have to replace it!!
