sloppy seam sealer #2028693
03/10/16 07:03 PM
03/10/16 07:03 PM
N of Detroit
DaveDudek Offline OP
N of Detroit
What are you guys using to reproduce the sloppy seam sealer in the trunk areas? Seems like everything I have to choose from is too thin to build up.
Dave Dudek
1st Factory Stock legal car in the 10`s!!! [/b]
FAST & Factory Stock Rules: www.fastraces.org
FAST 69 Hemi RR 9.98@139
Re: sloppy seam sealer [Re: DaveDudek] #2028761
03/10/16 08:28 PM
03/10/16 08:28 PM
Lee Co. Fla.
5carguy Offline
5carguy  Offline
Lee Co. Fla.
Try some brushable seam sealer.I use a cheap 1" brush that I cut the bristles to about 1" to 3/4".Slop is the bestlaugh2Available at any automotive paint store.Do not use 3M fast and firm.twocents
Re: sloppy seam sealer [Re: 5carguy] #2028857
03/10/16 11:02 PM
03/10/16 11:02 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Do the same.
If you the correct appearance it helps to drink 5-6 beers before you start. smile
Re: sloppy seam sealer [Re: Morty426] #2028874
03/10/16 11:34 PM
03/10/16 11:34 PM
Wisconsin
Stewpar Offline
Stewpar  Offline
Wisconsin
I used the 3M Ultra-pro Urethane #8361 seam sealer that comes in sausage tubes and it works great! You can apply it with a manual or electric caulk gun......... up
Admiration For Multiple Carburetor Vehicles...
Re: sloppy seam sealer [Re: DaveDudek] #2028998
03/11/16 03:15 AM
03/11/16 03:15 AM
Southeast PA
5wndwcpe Offline
5wndwcpe  Offline
Southeast PA
For brushable I like Wurth. If you use a chip brush, you can cut the bristles shorter to stiffen up the brush and drag it across the seam sealer. The hard part is trying not to make it look good.
1968 GTX hardtop
1968 Sport Satellite Convertible 383/4spd
1933 Plymouth coupe
2002 Ram 2500 oil burner 4x4
2015 Grand Cherokee
2013 Challenger
1957 Chrysler Saratoga
Man...I need a bigger freakin' garage.
Re: sloppy seam sealer [Re: DaveDudek] #2029220
03/11/16 03:10 PM
03/11/16 03:10 PM
N of Detroit
N of Detroit
Thanks guys!
Dave Dudek
Re: sloppy seam sealer [Re: DaveDudek] #2029256
03/11/16 03:59 PM
03/11/16 03:59 PM
South Dakota
hotairballoonpilot Offline
South Dakota
brushable from 3m here too.
Contact Me about AMD Prices
Re: sloppy seam sealer [Re: Stewpar] #2029281
03/11/16 04:38 PM
03/11/16 04:38 PM
muskegon MI
v cummins Offline
v cummins  Offline
muskegon MI
