pertronix with repro wires? #2029195
03/11/16 02:22 PM
03/11/16 02:22 PM
MERRILLVILLE, INDIANA
sunroof446 Offline OP
I am converting my factory dual point to pertronix and I am going to use there coil. Can I use the repro date coded wires or should I get a set of taylors? If I remember right they do not recommend using the repro wires with electronic ignition.
Re: pertronix with repro wires? [Re: sunroof446] #2029197
03/11/16 02:24 PM
03/11/16 02:24 PM
Ball Ground, Georgia
Dixie Offline
Dixie  Offline
I'm running a Pertronix in a dual point and a factory coil with repro wires. Works fine. You may want to ask whoever is making that recommendation, why?
Dixie Restoration Parts
Phone -(770) 975-9898
Phone Hours: M-F 10am-5pm EST
website: www.dixierestorationparts.com
email: mail@dixierestorationparts.com
Veteran owned small business
The Best Parts at a Fair Price.
Re: pertronix with repro wires? [Re: Dixie] #2029198
03/11/16 02:29 PM
03/11/16 02:29 PM
I think when I bought the repro wires a while back there was something in the instruction sheet about not recommended for electronic ignition. I know it will run, but how intense is the spark going to be?
Re: pertronix with repro wires? [Re: sunroof446] #2029367
03/11/16 07:47 PM
03/11/16 07:47 PM
Dixie Offline
Dixie  Offline
Not sure about that, but mine has no problems lighting the tires up at will. Maybe it isn't running at max potential, but I'm not racing it either. shruggy
I'd definitely be interested in knowing if there is a serious performance drop.
Re: pertronix with repro wires? [Re: Dixie] #2029445
03/11/16 10:18 PM
03/11/16 10:18 PM
Wires are made by lecrtric limited. I will give them a call.
