71 GTX pinstripe #2028652
03/10/16 05:47 PM
03/10/16 05:47 PM
Pa
mopglen Offline OP
mopglen  Offline OP
Pa
I need to add the side pinstripes to my 71 GTX. I need the correct width and black color, gloss or flat for it. One graphics supplier said they are 1/4 inch gloss. Is that correct? Thanks.
Re: 71 GTX pinstripe [Re: mopglen] #2028662
03/10/16 06:11 PM
03/10/16 06:11 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
71 GTX pin stripes were painted. Gloss in sheen.
1959 Bugeye Sprite
1967 Charger Black L code
1967 Coronet R/T Convert Green 440 auto bought from original owner
1968 Charger R/T Bronze 440 4 spd console AM/FM
1969 Super Bee WM21H B5 A40 D21 N96
1969 Barracuda Formula S 340 Convert pilot car
1969 Hemi Road Runner RM23J D32 Omaha orange 4.10 Dana N96 N85
1970 Super Bee WM23N FE5 V1X 3.91 axle package, N96
1970 Road Runner RM21N B3 V1X D13
1971 MG Midget
1971 Road Runner RM23H GW3, A57
1972 Road Runner RM23P FY1, D21
Re: 71 GTX pinstripe [Re: mopglen] #2028670
03/10/16 06:31 PM
03/10/16 06:31 PM
Pa
mopglen Offline OP
mopglen  Offline OP
Pa
Thanks. I still need the width.
T appreciate the reply.Glen
Re: 71 GTX pinstripe [Re: mopglen] #2028697
03/10/16 07:08 PM
03/10/16 07:08 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The width is approx .200, just a whisker over 3/16", as stated they were painted on, and the quality varied greatly, Trimbrite has a 3/16" wide "paint pinstripe" that has the effect of a brushed pinstripe line in it's premium pinstripe line, it's textured with a brush stroke and semi transparent micro brush lines of color, just like you'd see on a real painted pinstripe, retail is about $30 for 50 feet, I found it while doing the 71 GTX vert project
mike
Re: 71 GTX pinstripe [Re: mopglen] #2028971
03/11/16 02:13 AM
03/11/16 02:13 AM
Pa
mopglen Offline OP
mopglen  Offline OP
Pa
Thanks Mike. That is great. Any chance you have a part number?
Glen
Re: 71 GTX pinstripe [Re: mopglen] #2029133
03/11/16 12:34 PM
03/11/16 12:34 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Does the correctness of the stripe matter?
As Dayclona mentioned, the stripes were hand painted on at the factory and as such, their consistency varied considerably. The tape pin stripe will actually be much more consistent that the original stripes were. If that matters.
There are some repops of the original engineering drawings of these details floating around. I may even have some copies left over from my projects. Getting the bends around the wheel well openings right is the real test.
And any good pin stripe painter can whip them on in a few minutes. Sometimes there are pin stripe painters at car shows that do the stripes then and there.
Master, again and still
Re: 71 GTX pinstripe [Re: DaveRS23] #2029203
03/11/16 02:38 PM
03/11/16 02:38 PM
Western New York
sixpackbee Offline
sixpackbee  Offline
Western New York
Here is what I have.
1959 Bugeye Sprite
1971 MG Midget
Re: 71 GTX pinstripe [Re: mopglen] #2029324
03/11/16 06:23 PM
03/11/16 06:23 PM
Pa
mopglen Offline OP
mopglen  Offline OP
Pa
Thank you Dave and Sixpackbee for your input. That was helpful.
Glen
Re: 71 GTX pinstripe [Re: mopglen] #2029736
03/12/16 01:02 PM
03/12/16 01:02 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Here is the whole page:
Re: 71 GTX pinstripe [Re: mopglen] #2029997
03/12/16 10:56 PM
03/12/16 10:56 PM
Pa
mopglen Offline OP
mopglen  Offline OP
Pa
Thank you very much Dave. The drawing is a little hard to read. Is the stripe about 1/2 inch above the body line?
Appreciate your help.
Glen
Re: 71 GTX pinstripe [Re: mopglen] #2030035
03/13/16 01:02 AM
03/13/16 01:02 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Glen
No, the bottom edge of the stripe is approx 1.000 (1 inch) above the lower hard edge body line the entire length, I circled the key notes in the pic
Mike
Re: 71 GTX pinstripe [Re: mopglen] #2030074
03/13/16 01:57 AM
03/13/16 01:57 AM
Pa
mopglen Offline OP
mopglen  Offline OP
Pa
Thanks Mike. I got it now. I did email Trimbrite to try and get a part number for the tape if they still make it. You have been very helpful.
Glen
