how to test a stock voltage limiter out of the car #2028673
03/10/16 06:37 PM
03/10/16 06:37 PM
NO RUST IN AZ!!!
azmopar Offline OP
azmopar  Offline OP
NO RUST IN AZ!!!
is there a way to test a stock voltage limiter out of the car and not attached to the dash? its the 3 prong style
70 Challenger Convertible 340 six pak CLONE?
70 Duster real FM3 car
65 Dart Charger FOR SALE
#NONIKESEVER
A Real man aint afraid to drive PINK!!!!
67 Plymouth Valiant PILOT CAR 273 Commando 4 spd
Re: how to test a stock voltage limiter out of the car [Re: azmopar] #2028711
03/10/16 07:25 PM
03/10/16 07:25 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Hook up the ground the 12v in and check the output with a VOM .
Re: how to test a stock voltage limiter out of the car [Re: stumpy] #2028714
03/10/16 07:27 PM
03/10/16 07:27 PM
NO RUST IN AZ!!!
azmopar Offline OP
azmopar  Offline OP
NO RUST IN AZ!!!
Originally Posted By stumpy
Hook up the ground the 12v in and check the output with a VOM.
ok but which post is which the one soldered to the outside o the case I believe is ground one is marked IGN the 3rd isn't marked at all
#NONIKESEVER
Re: how to test a stock voltage limiter out of the car [Re: azmopar] #2028723
03/10/16 07:40 PM
03/10/16 07:40 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
The ground is the one soldered to the case. the one marked ign is 12v in and the unmarked is the output and will be fluctuating voltage.
Re: how to test a stock voltage limiter out of the car [Re: stumpy] #2028733
03/10/16 07:48 PM
03/10/16 07:48 PM
NO RUST IN AZ!!!
azmopar Offline OP
azmopar  Offline OP
NO RUST IN AZ!!!
ok thanks ill give that a try
#NONIKESEVER
Re: how to test a stock voltage limiter out of the car [Re: azmopar] #2028754
03/10/16 08:23 PM
03/10/16 08:23 PM
NC
1970A66 Offline
1970A66  Offline
NC
