Mopar 420 on Indy 360-1 heads #2028187
03/09/16 11:12 PM
03/09/16 11:12 PM
'murica
misfired Offline OP
misfired  Offline OP
'murica
Can it be done? If so how involved? Heads are the 245cnc 360-1, just curious if the bolt pattern is even the same. Obviously milling for deck height and variety in surfaces.
Thanks in advance
Re: Mopar 420 on Indy 360-1 heads [Re: misfired] #2028272
03/10/16 01:28 AM
03/10/16 01:28 AM
Hilltown Pa
1967dartgt Offline
1967dartgt  Offline
Hilltown Pa
Yes it can be done, a member here had one on some Brodix B1ba heads.
Brett Miller W9 cnc'd heads
STR Chassis fabraction
Re: Mopar 420 on Indy 360-1 heads [Re: misfired] #2028288
03/10/16 01:44 AM
03/10/16 01:44 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This was one of the very first one ever cast..
it was VERY rough on the ports and the plenum
so I cut it in half to port it..I fitted it to
my 9.2 deck W-9 then welded it back together..
was a lot of work.. but fun.. cant say how I
got it but I worked at the right place... I did
open it up for a 1050 dom
EDIT
I ended up buying a special welding torch to
weld the bottom of the plenum
wave
Re: Mopar 420 on Indy 360-1 heads [Re: MR_P_BODY] #2028554
03/10/16 02:45 PM
03/10/16 02:45 PM
dogdays Offline
dogdays  Offline
420? What have you been smoking?
I think the number you were trying for is 411.
R. coffee
Re: Mopar 420 on Indy 360-1 heads [Re: 1967dartgt] #2028559
03/10/16 02:48 PM
03/10/16 02:48 PM
Renton Washington
Triple Threat Offline
Renton Washington
Still do, Its all for sale in the classifieds!
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Mopar 420 on Indy 360-1 heads [Re: dogdays] #2028582
03/10/16 03:26 PM
03/10/16 03:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
R. coffee
You dont think its a 420?... here is my other one
EDIT
that one was 1st version.. they changed it 3 times
in total
wave
Re: Mopar 420 on Indy 360-1 heads [Re: dogdays] #2028643
03/10/16 05:19 PM
03/10/16 05:19 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
R. coffee
He's right, it's a 420. What is a 411 intake?
Re: Mopar 420 on Indy 360-1 heads [Re: Monte_Smith] #2028653
03/10/16 05:50 PM
03/10/16 05:50 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I know the chevy guys love the 420 intake
wave
Re: Mopar 420 on Indy 360-1 heads [Re: misfired] #2028682
03/10/16 06:49 PM
03/10/16 06:49 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
smoke
Re: Mopar 420 on Indy 360-1 heads [Re: misfired] #2028851
03/10/16 10:53 PM
03/10/16 10:53 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
Not sure if it's your plan to do what you asked,but if it was me...I'd take all the money and time wasted and invest it in the indy intake which can be OUTSTANDING if worked on by Brett or someone very good.
Re: Mopar 420 on Indy 360-1 heads [Re: misfired] #2028899
03/11/16 12:14 AM
03/11/16 12:14 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
What if it's been worked on and the owner is kicking around ideas to find a little more? ?
Re: Mopar 420 on Indy 360-1 heads [Re: misfired] #2028904
03/11/16 12:22 AM
03/11/16 12:22 AM
'murica
misfired Offline OP
misfired  Offline OP
'murica
Thanks for the replies, not sure if I will go through with this, my Indy is worked by a reputable Porter and dominator converted, however, seems like it would need a fair bit of welding to get things ported/blended properly. So was thinking up options, like when will someone offer an as cast dominator small mopar intake....
Re: Mopar 420 on Indy 360-1 heads [Re: misfired] #2029219
03/11/16 03:09 PM
03/11/16 03:09 PM
dogdays Offline
dogdays  Offline
My only excuse is:
I'm so used to seeing "420" as shorthand for pot, marijuana, grass, weed, reefer.
The other 3 digit number starting with a 4 that came to mind was 411, shorthand for information.
So I translated it a little differently as asking, "What's the 411 on Indy 360-1 heads", but putting the wrong number in the question made it funny.
My apologies......
R.
