Re: Difference between double nickel and triple plating?
[Re: stat5]
#202688
01/24/09 06:08 PM
01/24/09 06:08 PM
Posts: 5,193 NEW JERSEY
AARCONV
NEW JERSEY
[Re: AARCONV]
#202689
01/24/09 06:11 PM
01/24/09 06:11 PM
Posts: 7,647 Houston Texas
PAINT IT BLACK
Got a CHIP on my shoulder
Houston Texas
shouldn't be wavy either
Yeah, I just blame that on shortcutting the prep... I'll make sure that gets fixed this time around.
[Re: PAINT IT BLACK]
#202690
01/24/09 06:13 PM
01/24/09 06:13 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
Ask the prospective shops if they use "Hexavalent" or "Trivalent" plating. The chemistry is different. Hex is mor hazardous and expensive, and surprise--Better. Trivalent is becoming more and more common, and while it can be done well, its not quite as good. When you find a shop that still does Hex, its a pretty good indicator that they perform good work and have pride in their work. Think of Tri as cutting a corner, if they cut that corner, what OTHER corners do they cut???
[Re: Pacnorthcuda]
#202691
01/25/09 05:09 PM
01/25/09 05:09 PM
Posts: 1,369 Ohio
3404
Ohio
Trivalent usage has nothing to do with cutting corners, where did you come up with that? Nor are they cheaper, did you make that up also? Trivalents are used to be ROHS compliant and to meet EPA and European standards, which since you don't know means they cost MORE money to buy and use. Hexvalent chromates and chromes are more carcinogenic and that is why most aren't used and why most aren't allowed to be used on automotive parts or anything that is sent to European nations. The goal they have is for anything that ends up in a land fill to be environmentally friendly or recyclable.
Now since trivalents do not have the same heavy chromes in them as the hexvalents but have to meet or exceed the haxvalent standards do you think they are cheaper or the shops using them are Cutting Corners? I think not.
If the parts rusted then they probably didn't get enough chrome over the nickel. Nickel offers little or almost no protection, nickel is porous and the chrome seals it. That is why the back sides always seem to rust, they get almost no chrome just nickel. If you bumper has a goldish color you are seeing the nickel.
By the way I know very high end chrome shops that use Trivalent chromes and Non-cyanide coppers and their work is flawless
[Re: 3404]
#202693
01/25/09 07:19 PM
01/25/09 07:19 PM
Pacnorthcuda
In Washington State we have both types being done. I stated Trivalent was more environmentally friendly, as you concur. I can tell you that the HIGH end shops around here still use hexavalent (Art Brass Plating, Mastercraft, etc) and they have told me its more expensive. Think about this....COULD the 'more expensive' part be due to the disposal of cyanide bearing plating baths??? I think so. Can Trivalent not be done well? Of course it can, I never said it couldn't.
You can have your Tri, make mine hex.
BTW...its "Hexavalent"
[Re: 3404]
#202694
01/25/09 07:29 PM
01/25/09 07:29 PM
Pacnorthcuda
more info Letter 16675
Hexavalent Chrome or Trivalent Chrome ++
Please can you tell me the main differences between hexavalent chrome plating and trivalent chrome plating.
Scott Campbell Havelock Europa - Dalgety Bay, Fife, Scotland
-------------------------------------------------------------------------------- ++ Hexavalent chrome plating is done out of a chromic acid (H2CrO3) solution in which the chrome is at a +6 oxidation state. This is the traditional approach that has been around for 80 years or so. Some hexavalent plating solutions are generic, some are proprietary.
Trivalent plating is done out of a solution where the chrome is in the +3 oxidation state. This is the newer approach and has been around for 25 years or so. All trivalent chromium plating is based on proprietary baths and usually requires some special equipment features like carbon anodes, or diaphragms to separate the anodes from the plating zone.
Reputedly, trivalent chromium baths involve less dragout, are easier to waste treat, have less stringent ventilation requirements, are not as subject to very low throwing power, etc. On the down side they can plate only very thin layers suitable for decorative plating not hard chrome plating,and the color is a little "off" from the traditional.
