Page 6 of 6 1 2 3 4 5 6
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2154094
09/13/16 11:36 PM
09/13/16 11:36 PM
Sacramento,California
JRepucci Offline OP
JRepucci  Offline OP
Almost ready to start...
Any other late build A bodies with blue 340 engines out there?
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2154161
09/14/16 01:13 AM
09/14/16 01:13 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Kent,
Many head and block castings (all engines) had splotches of paint on them prior to the engine paint being added, probably denoting some type of machining process or QC inspection process. This is an original paint engine, that pink paint under the orange is the same type as your engine has.
Re: 1969 340... Blue or Turquoise? [Re: ScottSmith_Harms] #2154263
09/14/16 10:16 AM
09/14/16 10:16 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
Originally Posted By ScottSmith_Harms
Kent,
Cool.
BTW, this is how I cleaned up the heads in my kitchen: After scraping off the thick crud with ice cream sticks, I applied a few coats of cooking oil with a tooth brush and wiped off. The cooking oil works pretty good.
Re: 1969 340... Blue or Turquoise? [Re: kentj340] #2179682
10/21/16 12:34 PM
10/21/16 12:34 PM
New York
rarefish Offline
rarefish  Offline
New York
Here are a few pics of my 340 from my 1969 Dart. This is a original 10,000 mile engine that was untouched until I took it apart last year. I also have the pink paint on the heads between the exhaust ports.
Re: 1969 340... Blue or Turquoise? [Re: rarefish] #2179688
10/21/16 12:45 PM
10/21/16 12:45 PM
New York
rarefish Offline
rarefish  Offline
New York
Passenger side pic. You can really see the engine paint shadowing that the exhaust manifold caused.
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2179990
10/21/16 10:20 PM
10/21/16 10:20 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Great pics. So the dip stick handle has never been repainted? How about the water pump bolts, any signs of blue paint on the ones that hold the brackets on?
Re: 1969 340... Blue or Turquoise? [Re: ScottSmith_Harms] #2180810
10/23/16 01:26 PM
10/23/16 01:26 PM
New York
rarefish Offline
rarefish  Offline
New York
Dip stick handle is original. The original motor was pulled out in 1974 and a red painted 1968 340 slightly built engine was installed for drag racing. Some of the bolts and brackets from the 69 motor were installed on the 68 motor.
Here are a few more pics. The motor is Tourquoise. It looks like he swapped the bypass hose from the 69 motor to the 68 motor as you can see the engine paint still on the hose clamps. Boy, now I wish that I had taken more photos.
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2180823
10/23/16 01:50 PM
10/23/16 01:50 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Those pics help, dip stick is as expected as is the blue paint on the bolt heads which is what I had expected to see.
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2180858
10/23/16 02:55 PM
10/23/16 02:55 PM
JRepucci Offline OP
JRepucci  Offline OP
Great pictures. What is the VIN# and SPD?
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2190339
11/05/16 10:22 PM
11/05/16 10:22 PM
PA. USA
69BBCUDA4SPD Offline
PA. USA
My dad bought a 69 barracuda new. If he remembers right he said his 340 was orange. Is his memory right ?
Re: 1969 340... Blue or Turquoise? [Re: 69BBCUDA4SPD] #2190358
11/05/16 10:38 PM
11/05/16 10:38 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Not likely, maybe he was recalling the bright red air cleaner "340 Four Barrel" call out.
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2244085
01/30/17 05:30 PM
01/30/17 05:30 PM
JRepucci Offline OP
JRepucci  Offline OP
Running and ready for first test drive... BUT for some reason I have a front brake caliper that will not release frown
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2244087
01/30/17 05:33 PM
01/30/17 05:33 PM
JRepucci Offline OP
JRepucci  Offline OP
couple more
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2246822
02/03/17 09:39 PM
02/03/17 09:39 PM
MO
cdp Offline
cdp  Offline
MO
what exhaust did you choose? Car looks great BTW.
Re: 1969 340... Blue or Turquoise? [Re: cdp] #2246966
02/04/17 01:31 AM
02/04/17 01:31 AM
JRepucci Offline OP
JRepucci  Offline OP
TTI 2.5"... car sounds amazing
Re: 1969 340... Blue or Turquoise? [Re: JRepucci] #2676020
07/09/19 03:46 PM
07/09/19 03:46 PM
canada
seamack3 Offline
seamack3  Offline
canada
An early build 1969 GTS convertible with original red 340.
Re: 1969 340... Blue or Turquoise? [Re: seamack3] #2676107
07/09/19 09:41 PM
07/09/19 09:41 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
And your'e SPD is? Should be before September 9th or shortly thereafter... scope
JB Rhinehart, Realist
A-Body's RULE!
