Stage VI heads #2025691
03/06/16 01:25 PM
03/06/16 01:25 PM
Riverside, Ca
R70RUNNER Offline OP
Riverside, Ca
I'll ask over here since probably more guys have experience. Ran into a new in the box pair of these that are 18yrs old. The version with std port size but raised intake, the chambers are smallish and heart shaped. Any idea what the chambers should be CC wise? What they were advertised as? anything in particular to inspect on them for flaws. I know some had issues, any help with knowlege would be appreciated
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
Re: Stage VI heads [Re: R70RUNNER] #2025774
03/06/16 04:01 PM
03/06/16 04:01 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Advertised is 78cc. Mine were ported version, with polished chambers, they checked out to be 84cc.
Check the foundry casting ID. The early "Winters" casting were the poor ones to avoid. There should be a casting date label somewhere on them.
Post a pic of the foundry mark and we can verify good vs bad.
Re: Stage VI heads [Re: R70RUNNER] #2025782
03/06/16 04:23 PM
03/06/16 04:23 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Got pics?
- Foundry symbol on top of head
- Chamber
- Intake & exhaust bowls
That would help to narrow down the "vintage" of the heads.
If you haven't read this thread from the old Moparts Tech Archives lined from the home page, it's probably worth your time, too.
Re: Stage VI heads [Re: R70RUNNER] #2025810
03/06/16 05:38 PM
03/06/16 05:38 PM
Riverside, Ca
Riverside, Ca
Thanks guys. I have received a couple pics but oddly enough not one straight down into the top of the heads. I've asked for it but hasn't come over yet. If he avoids that view perhaps there's a reason. They're reasonably priced, but if they're more trouble to correct or make solid enough to be dependable I won't bother. If I can get a look at them or more pics I'll post up. Appreciate the help! As I recall the winters marks I've seen are a snowflake with a "w" in the center is that correct?
Re: Stage VI heads [Re: R70RUNNER] #2025860
03/06/16 06:49 PM
03/06/16 06:49 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Have someone who is really good with heads look them over very thoroughly before handing over any $$$.
They can easily cost too much to straighten out to be worthwhile.
As for chamber volume, the only ones I recall actually being close to the 78cc spec were the last version from the Zeus foundry. The others were all over the place...... Up to around 92cc's.
IMO, they would have to be priced VERY attractively to be worth messing with them, unless you have the capabilities to do most of the work yourself.
Re: Stage VI heads [Re: fast68plymouth] #2025945
03/06/16 08:41 PM
03/06/16 08:41 PM
BradH Offline
BradH  Offline
Having been one who paid the extra $$$ to straighten out a variety of QC issues, etc., "priced VERY attractively" would mean basically FREE.
Re: Stage VI heads [Re: R70RUNNER] #2025972
03/06/16 09:10 PM
03/06/16 09:10 PM
OH.
7074cuda Offline
7074cuda  Offline
OH.
I have a set of Winters VI cant remember if a big W or small made the difference of a good set Nick at Compu-Flow straighten mine out and got them at around 77cc and flow about 310 at .600.I got mine real reasonably cheap but still have over 2G's in them there are better alternatives.
Re: Stage VI heads [Re: R70RUNNER] #2026141
03/06/16 11:56 PM
03/06/16 11:56 PM
On the run…
BloFish Online penguin-006
BloFish  Online Penguin-006
On the run…
Here is a pic of my VI heads. The good version.
It really doesn't matter whether you win or lose…
as long as you look good doing it!
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Stage VI heads [Re: R70RUNNER] #2026150
03/07/16 12:05 AM
03/07/16 12:05 AM
Idaho
LaRoy Engines Offline
Idaho
Avoid Stage VI heads unless they are free and you can work on them yourself. There are too many better options.
Re: Stage VI heads [Re: LaRoy Engines] #2026164
03/07/16 12:15 AM
03/07/16 12:15 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I agree, remember seeing a raw set of castings at Summit and they were very rough and unfinished. They are decent after you Finnish them up Porting, machining ETC. Better be close to free IMO too.
Re: Stage VI heads [Re: R70RUNNER] #2026276
03/07/16 02:21 AM
03/07/16 02:21 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I was able to score a set of Chapman ported heads with new T&D rockers and shafts for a blown 500 inch wedge.
Check out these flow charts and don't forget to save them!!
http://users.erols.com/srweiss/tablehdc.htm#Chrysler_Big_Block
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Stage VI heads [Re: BloFish] #2026324
03/07/16 09:21 AM
03/07/16 09:21 AM
OH.
7074cuda Offline
7074cuda  Offline
OH.
I have this Winters mark on my heads.
Re: Stage VI heads [Re: 7074cuda] #2026542
03/07/16 03:48 PM
03/07/16 03:48 PM
dogdays Offline
dogdays  Offline
IIRC that's the Zeus foundry mark.
The Winters is the W inside the snowflake.
I could be wrong about the first, I'm sure someone will tell me if I am.
R.
Re: Stage VI heads [Re: R70RUNNER] #2026547
03/07/16 04:00 PM
03/07/16 04:00 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
Run them over to Stage VI.... They are not that far from you.... smile
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Stage VI heads [Re: R70RUNNER] #2026607
03/07/16 05:11 PM
03/07/16 05:11 PM
So. Burlington, Vt.
So. Burlington, Vt.
The Zeus heads have the word "Zeus" cast right into the head and had the least issues.
Someone will have chime in on this...... But as I remember it, the Chapman stage vi's were cast by the Zeus foundry as well, although those were their own casting.
Re: Stage VI heads [Re: R70RUNNER] #2026829
03/07/16 10:49 PM
03/07/16 10:49 PM
Riverside, Ca
Riverside, Ca
I'm going to look them over in the morning so I'll know more. I'll share my findings. More to follow.
Re: Stage VI heads [Re: racerhog] #2026853
03/07/16 11:29 PM
03/07/16 11:29 PM
On the run…
On the run…
What, where is this Stage VI?
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Stage VI heads [Re: R70RUNNER] #2026917
03/08/16 12:37 AM
03/08/16 12:37 AM
Riverside, Ca
Riverside, Ca
Couple pics of the numbers. And castings.
Re: Stage VI heads [Re: R70RUNNER] #2026960
03/08/16 01:28 AM
03/08/16 01:28 AM
On the run…
On the run…
My cast date is...
‘65 A100
‘69 ‘Cuda
‘73 Vega GT
‘06 Mega Cab
‘14 Mercedes SLK
Re: Stage VI heads [Re: R70RUNNER] #2026993
03/08/16 02:24 AM
03/08/16 02:24 AM
So. Burlington, Vt.
So. Burlington, Vt.
So, they are Zeus heads. The best of the group, but you should still have them checked out.
And, you'd still need to be into them pretty cheap to make it worthwhile.
Also, be sure your expectations about what you can do with those heads(without spending more than you would on other heads) fit your needs and budget.
