Re: 750 Street Demon on a big block?
[Re: PossessedDuster]
#2024689
03/04/16 10:06 PM
03/04/16 10:06 PM
RapidRobert
the CFM is in a good range for a 440 & iirc the SD has gotten good reviews. here's a BTT for ya
#2024700
03/04/16 10:25 PM
03/04/16 10:25 PM
RapidRobert
In that case definitely hang loose & wait for more input. If I was going to spring for a new carb I would want one that has all of the systems adjustable so it can be dialed in spot on (with the LM1)
#2024710
03/04/16 10:42 PM
03/04/16 10:42 PM
Posts: 12,171 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
The Street Demons are the best street carbs out there, in my opinion. They are calibrated better than most and have features that none of their competitors have. Having said that, they are a pain to tune. And the parts are just about always mail order. I don't know of any place that stocks tuning parts and there aren't that many anyway. So if you into tuning to a razor's edge, something else might be the way to go. If, however, you want a carb that is the most likely to run good out of the box and have probably the best throttle response, then this is the carb for you.
Master, again and still
#2024759
03/05/16 12:00 AM
03/05/16 12:00 AM
Posts: 20,188 Park Forest, IL
slantzilla
Park Forest, IL
Demon carbs and BG products in general were a real crap shoot when Barry Grant owned the company. Now that they are part of Holley I think they have gotten a lot better. Biggest issues people had were float bowls being full of crap. Pretty annoying on something you just plunked down your cash for.
With no converter and 3.23 gears a 750 should make you very happy.
[Re: slantzilla]
#2024989
03/05/16 02:10 PM
03/05/16 02:10 PM
Posts: 4,780 Holland MI Ottawa
2boltmain
Holland MI Ottawa
I cannot speak from actual ownership. I have watched many of the youtube evaluations and advertisements of the Street Demon carbs and it seems this design is a superb STREET DAILY DRIVER high performance carburetor. The designer worked for Carter back in the day and with this carb was allowed to incorporate things to improve on 1970s tech. None of the evaluaters will say it but the street demon is obviously an improved version of the thermoquad. Id love to buy 2 of them for my future 360 dual quad motor but the street demons only come in 625 and 750cfm sizes and I simply want 2 500cfm`s which means ill go Edelbrock. http://www.mooregoodink.com/news/street-demon-an-interview-with-its-designer/
Keep old mopars alive.
#2025681
03/06/16 01:14 PM
03/06/16 01:14 PM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
Had a 750 vac one time. An old BG version and can attest to the crap in it. Basically pull it apart and flush the metal shavings and machining remnants out of the metering block and bowls it was fine. Poor QC but good carb.
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
