Steering Column Bushing - Mid '70's - Updated #2024191
03/04/16 12:18 AM
03/04/16 12:18 AM
Washington State
70Duster440 Offline OP
Washington State
We're swapping a column shift column out for a floor shift column. The floor shift column had this plastic bushing at the end of the tube. The column shift column did not have the bushing at the end - though there may be been one at one time.
I could see how the bushing might help support the end of a shift lever tube but what purpose would it serve, if any, in the floor shift column? Was this just a 'luck-of-the-draw' on the assembly line?
Re: Steering Column Bushing - Mid '70's [Re: 70Duster440] #2024594
03/04/16 06:26 PM
03/04/16 06:26 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If the steering shaft can wobble around that much on the bottom, I suspect it won't be doing the turn signal switch, or the wires passing through the column, much good. The difference in the life expectancy of the turn signal switch or wires with or without it might not be a lot, but every column I ever remember looking at had something at the bottom of the column. Of course, I can't say that I looked at every column I ever took out. Gene
Re: Steering Column Bushing - Mid '70's [Re: 70Duster440] #2024749
03/04/16 11:46 PM
03/04/16 11:46 PM
Washington State
Washington State
Thanks. That bushing comes nowhere near supporting the shaft. Like I said, I put in in the other column and it fits around the end of the shift tube nicely - like it might actually belong there. In this application, I don't see the point. And once the shaft is connected to the steering box, it's not going to flop around.
Sure like to know what all is supposed to be there. Anyone have a '70's manual trans truck?
Re: Steering Column Bushing - Mid '70's [Re: 70Duster440] #2025736
03/06/16 02:38 PM
03/06/16 02:38 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
the newer trucks (80s) have a bearing there to support the shaft. It needs to be supported.
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Steering Column Bushing - Mid '70's [Re: 70Duster440] #2027690
03/09/16 02:45 AM
03/09/16 02:45 AM
Washington State
Washington State
Well, we broke the column down and painted the pieces last weekend and then decided to take another look at some kind of bearing support.
So, I picked up a flanged bearing with a 2" OD and .75" ID, some nuts, and set screws. Had already cut off the end of the column tube before painting.
Ground some flats in the outer race for the set screws to contact.
Seems the column and shaft will have to be much more accurately aligned with the steering box. We'll see how it works.
Re: Steering Column Bushing - Mid '70's [Re: 70Duster440] #2027693
03/09/16 02:49 AM
03/09/16 02:49 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Are you going to install the steering gear box reinforcement bracket on the truck also?
Re: Steering Column Bushing - Mid '70's [Re: stumpy] #2027694
03/09/16 02:56 AM
03/09/16 02:56 AM
Washington State
Washington State
Was offered a used one but the seller didn't follow through.
Re: Steering Column Bushing - Mid '70's [Re: 70Duster440] #2028951
03/11/16 01:44 AM
03/11/16 01:44 AM
5thAve Offline
5thAve  Offline
How hard is it to get that reinforcement bracket off when you are junk yard scrounging?
Re: Steering Column Bushing - Mid '70's [Re: 70Duster440] #2028966
03/11/16 02:07 AM
03/11/16 02:07 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It attaches with the steering box bolts and at least one bolt in the front crossmember. It fits inside the frame rail.
Re: Steering Column Bushing - Mid '70's [Re: 70Duster440] #2029018
03/11/16 05:28 AM
03/11/16 05:28 AM
Washington State
Washington State
It's slim pickings for trucks of that era around here. It's been awhile since I checked though.
Re: Steering Column Bushing - Mid '70's [Re: 70Duster440] #2030779
03/14/16 08:58 AM
03/14/16 08:58 AM
Pennsylvania
Red 79 Offline
Red 79  Offline
Pennsylvania
I've been looking for the re-enforcing bracket for two years with no luck
Re: Steering Column Bushing - Mid '70's [Re: 70Duster440] #2038845
03/25/16 11:26 PM
03/25/16 11:26 PM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
Re: Steering Column Bushing - Mid '70's [Re: Ramtough] #2039117
03/26/16 12:41 PM
03/26/16 12:41 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
Originally Posted By Ramtough
David S.
Part Time Owner
Dodge Connection
www.dodgeconnection.com
904-209-9388
