440 six pack shorty plugs #2025598
03/06/16 11:23 AM
03/06/16 11:23 AM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
I just dropped a 440 six pack in a 74 Challenger. Forgot about the tight spark plug vs header fit. What is the correct short spark plug and any advice on a wire set would help. It is a pump gas build street strip Farm Car deal. Patina everywhere but should run good.
CALMED THE QUAKE!!!(AGAIN!)
Re: 440 six pack shorty plugs [Re: Spyphish] #2025837
03/06/16 06:08 PM
03/06/16 06:08 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
What kind of heads?
Re: 440 six pack shorty plugs [Re: bobby66] #2025847
03/06/16 06:30 PM
03/06/16 06:30 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Promaxx 9440 from Jegs. 84cc since this was an RV motor with low compression.
Re: 440 six pack shorty plugs [Re: Spyphish] #2025857
03/06/16 06:47 PM
03/06/16 06:47 PM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Champion J12YC always worked for me.Got 90 degree boots and terminals from NAPA, wire also, made all wires up myself.
Re: 440 six pack shorty plugs [Re: Spyphish] #2025875
03/06/16 07:17 PM
03/06/16 07:17 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
those heads probably need a 3/4" reach plug vs an iron head 3/8" reach. if so, go down to wal-mart and grab some autolite 3924's.
Re: 440 six pack shorty plugs [Re: lewtot184] #2026465
03/07/16 02:12 PM
03/07/16 02:12 PM
dogdays Offline
dogdays  Offline
Better get'em fast, in my area Walmart is blowing out most of the less expensive spark plugs.
R.
Re: 440 six pack shorty plugs [Re: dogdays] #2026781
03/07/16 09:35 PM
03/07/16 09:35 PM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
Here are the Accel shorty plugs that fit most aftermarket aluminum heads.
http://www.summitracing.com/parts/acc-0416s-4
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: 440 six pack shorty plugs [Re: Spyphish] #2026791
03/07/16 09:56 PM
03/07/16 09:56 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
those heads are edelbrock clones and will have to have a 3/4" reach plug.
Re: 440 six pack shorty plugs [Re: lewtot184] #2026840
03/07/16 11:07 PM
03/07/16 11:07 PM
Louisiana
Spyphish Offline OP
Spyphish  Offline OP
Louisiana
Your right. Correct shorty plugs here tomorrow. Now the thing will only idle with toothpicks stuck in vertical air bleeds on center carb. I have printed the 6P tuning write up so fine tuning in the morning. Cam and headers must not like stock settings. Thanks Phish
