T&D rocker info #2024948
03/05/16 12:44 PM
03/05/16 12:44 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
can anyone tell me if these rockers are actually for indy -1s The part number on the box is 8210.
Re: T&D rocker info [Re: mac56] #2024956
03/05/16 01:06 PM
03/05/16 01:06 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Looks like b1 stands
....BAD A$$ STREET CAR.....
Re: T&D rocker info [Re: mac56] #2024960
03/05/16 01:12 PM
03/05/16 01:12 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Their online product listing ( http://www.tdmach.com/mopar.html )
says Indy 440-1, but I agree those stands aren't what I'd have expected for that application unless the cast-in pedestals were milled off.
Re: T&D rocker info [Re: BradH] #2024983
03/05/16 02:00 PM
03/05/16 02:00 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I agree they dont say on the web site that you must do that.
Re: T&D rocker info [Re: mac56] #2025054
03/05/16 03:38 PM
03/05/16 03:38 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
IIRC members HardcoreB and DVW both milled the stands off of their -1's to correct the valve train geometry so perhaps that what is happening here. Isn't the spec on -1 intake rockers .800 for the offset? Those look to have lots offset!
Re: T&D rocker info [Re: Jeremiah] #2025075
03/05/16 04:04 PM
03/05/16 04:04 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I didnt measure the offset. They are 1.5 ratio though.
Re: T&D rocker info [Re: n20mstr] #2025084
03/05/16 04:22 PM
03/05/16 04:22 PM
iagree I just finished assembling a B1, those are identicle to the T&D furnished by Koffels for those heads up
if your going to buy a new set of rockers for your motor look at increasing the rocker ratio to help the motor breathe better work thumbs twocents
Re: T&D rocker info [Re: Cab_Burge] #2025237
03/05/16 08:58 PM
03/05/16 08:58 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I already own these and dont need them. I am trying to make sure they are what the previous owner said they are.
Re: T&D rocker info [Re: mac56] #2025443
03/06/16 01:42 AM
03/06/16 01:42 AM
New York, USA
Chargerfan68 Offline
New York, USA
I just got a set of 8210 from Duane for my Indys, so I guess they are also for a pair of -1's. They obviously don't have the pedestal blocks on mine.
Re: T&D rocker info [Re: Chargerfan68] #2025595
03/06/16 11:19 AM
03/06/16 11:19 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Those are for B1 heads. The intake offset will determine if they are for B1 originals or B1 MC. I dont remember what the offset difference is though. B1s for sure.
Re: T&D rocker info [Re: mac56] #2025783
03/06/16 04:28 PM
03/06/16 04:28 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Why would they do b1s in a 1.5 rocker?
Re: T&D rocker info [Re: mac56] #2025801
03/06/16 05:14 PM
03/06/16 05:14 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
What makes you think they are 1.5's?
Getting old just means you were smarter than some and luckier than others.
Re: T&D rocker info [Re: dannysbee] #2025812
03/06/16 05:42 PM
03/06/16 05:42 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
They have 1.5 stamped on them
Re: T&D rocker info [Re: mac56] #2025820
03/06/16 05:51 PM
03/06/16 05:51 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The blocks don't automatically make them for a B-1. They will work on anything if the spacing is right, offset is right. Not unusual to machine pedestals off any alum head.
The 8210 part number I am sure is just reference to the rocker body part number........not mounting
Re: T&D rocker info [Re: mac56] #2025821
03/06/16 05:54 PM
03/06/16 05:54 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Possibly packaged and stamped wrong? I agree 1.5 rocker for a b1 does not seem logical.
Re: T&D rocker info [Re: mac56] #2025827
03/06/16 05:57 PM
03/06/16 05:57 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
I will give T&D a call and see what they say.
Re: T&D rocker info [Re: mac56] #2026458
03/07/16 02:05 PM
03/07/16 02:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Looking at the t&d site, there is a different part number for the -1 and B1 heads, however the offsets for both are shown as the same. It could be that the only difference between them, as sold by t&d is that the B1 rocker set comes with the stands.
And, t&d does show a part number for a "1.52" ratio set for B1 heads.
I'd say a call to t&d would clear things up.
Re: T&D rocker info [Re: fast68plymouth] #2026524
03/07/16 03:30 PM
03/07/16 03:30 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
those are B-1 p/n 8010 1.5 ratio rackers. my twocents they do make them 1.5 for b-1.. shruggy
Re: T&D rocker info [Re: mac56] #2027266
03/08/16 04:11 PM
03/08/16 04:11 PM
ontario canada
mac56 Offline OP
mac56  Offline OP
ontario canada
Well I called t&d today. He was a little vague. He says the part number is for -1s and would not have stands. He said somebody just put them in that box but I got them from the original guy that ordered them and he thought they were wrong for him because he had indy -1cs. But Im leaning toward box wrong b1 stuff
Re: T&D rocker info [Re: mac56] #2027271
03/08/16 04:23 PM
03/08/16 04:23 PM
So. Burlington, Vt.
So. Burlington, Vt.
Did you ask if the b1 and -1 used the same rocker bodies?
