T&D rocker info
#2024948
03/05/16 12:44 PM
03/05/16 12:44 PM
Posts: 976 ontario canada
mac56
ontario canada
can anyone tell me if these rockers are actually for indy -1s The part number on the box is 8210. Thanks
Re: T&D rocker info
[Re: mac56]
#2025443
03/06/16 01:42 AM
03/06/16 01:42 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I just got a set of 8210 from Duane for my Indys, so I guess they are also for a pair of -1's. They obviously don't have the pedestal blocks on mine.
Re: T&D rocker info
[Re: mac56]
#2025801
03/06/16 05:14 PM
03/06/16 05:14 PM
Posts: 5,160 Texas
dannysbee
Texas
What makes you think they are 1.5's?
Getting old just means you were smarter than some and luckier than others.
Re: T&D rocker info
[Re: mac56]
#2025820
03/06/16 05:51 PM
03/06/16 05:51 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
The blocks don't automatically make them for a B-1. They will work on anything if the spacing is right, offset is right. Not unusual to machine pedestals off any alum head.
The 8210 part number I am sure is just reference to the rocker body part number........not mounting
Re: T&D rocker info
[Re: mac56]
#2025821
03/06/16 05:54 PM
03/06/16 05:54 PM
Posts: 5,160 Texas
dannysbee
Texas
Possibly packaged and stamped wrong? I agree 1.5 rocker for a b1 does not seem logical.
Re: T&D rocker info
[Re: mac56]
#2026458
03/07/16 02:05 PM
03/07/16 02:05 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Looking at the t&d site, there is a different part number for the -1 and B1 heads, however the offsets for both are shown as the same. It could be that the only difference between them, as sold by t&d is that the B1 rocker set comes with the stands. And, t&d does show a part number for a "1.52" ratio set for B1 heads.
I'd say a call to t&d would clear things up.
Re: T&D rocker info
[Re: mac56]
#2027271
03/08/16 04:23 PM
03/08/16 04:23 PM
fast68plymouth
So. Burlington, Vt.
Did you ask if the b1 and -1 used the same rocker bodies?
