Re: 74 dart gas gauge and anti-freeze out of a header bolt
[Re: dart67]
#2025063
03/05/16 03:48 PM
03/05/16 03:48 PM
Posts: 3,394 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
Yep wet header bolts on a big-block. That's why so many prefer to run studs and nuts instead of bolts (if they fit). Less chance of coolant leaks.
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: dart67]
#2025337
03/05/16 11:27 PM
03/05/16 11:27 PM
RapidRobert
You might get an OE type threaded stud with the smooth shoulder in the middle & mockup & you only need enough (fine) threads on the outer end of it so the nut fits flush with the end of the threads when tightened (take header gasket into consideration) then trim the excess. You can also get a thin high grade nut for even more gain. Use some gasket cement on the inside (coarse) threads
