Tow Package option; 727 transmission cooler at radiator?
#2024958
03/05/16 01:10 PM
03/05/16 01:10 PM
Posts: 7,548 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Two questions;
1.) My brother has a beat up '69 Coronet H code with a 26" radiator and "Tow Package" option. But some of the car is apart and not necessarily complete. He and I wonder if his 727 tranny with the Tow option would have come with a dedicated tranny oil cooler in front of the radiator. Anyone here know?
As we were pondering the question above, we came up a second question we don't know the answer to;
2.) The "standard" tranny fluid lines between the transmission and radiator bottom tank; are they for cooling the tranny fluid, or are they actually for warming up the tranny on start up? or both?
Thanks! - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Tow Package option; 727 transmission cooler at radiator?
[Re: babarracuda]
#2025080
03/05/16 04:17 PM
03/05/16 04:17 PM
Posts: 26,470 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The towing package parts list doesn't mention a trans cooler in '69. While the "cooler" in the radiator is obviously intended for cooling it does also act to warm up the fluid in extreme cold climates where the fluid might otherwise never reach operating temperature.
[Re: 67SATisfaction]
#2025917
03/06/16 08:08 PM
03/06/16 08:08 PM
67SATisfaction
Albany, NY
Thanks guys, It's a decent start - the car also has AC, so there is the evaporator in front (looks like a small radiator, right?). I'll make sure he scrutinizes the plumbing to understand the AC lines, he no idiot, but still make sure he understands they aren't tranny lines. He's not towing anything with it, so if it looks right, I'll tell him to just hook up the tranny lines to the radiator bottom tank.
Cheers, - Art
