Re: ******1972-80 dodge trucks ********
[Re: B1Frank]
#2024318
03/04/16 08:36 AM
03/04/16 08:36 AM
Posts: 27,728 places
79powerwagon
places
The rules for DOT and TC state that the placement of the center ID lights (the three in the middle) are to be no further apart than 12" US, and the two outside lights are placed as far out as practicable. So, find your center one, measure out 6" each way (that's your 3 centers) and then as far to the edges for the remaining two as is practical (I don't know why they use the word practicable). Of course, your truck doesn't NEED these lights at all (under 80" and under 10,000 lbs), but people stick them on all the time. It's not against the rules or laws to run them unless you ARE OVER 80" wide AND over 10,001 lbs. Now, the more important thing when installing these is to understand that Dodge trucks have a dual-skin roof system. You will have difficulty running wires to these lights. I was lucky on my PW as I had an original sunroof which I removed that allowed access to that gap between the inner and outer skins. I found a cheesy way to then run the power wire down the A pillar. In hindsight, I should have run the wire across the ceiling to the rear of the cab, then down to the floor, then back to the front of the cab to teh dash. Too much info?
[Re: B1Frank]
#2024569
03/04/16 05:33 PM
03/04/16 05:33 PM
dogdays
Practicable - what you are able to put into practice. It's used a lot in Government specs.
R.
My $500 F150 has them, why on a half ton? A hailstorm wiped them all out, now I have to buy new ones. Bummer.
[Re: dogdays]
#2024707
03/04/16 10:40 PM
03/04/16 10:40 PM
Posts: 6,024 Morningside
AdventurerSport
waaaay out there in left field
Morningside
My 76 W100 (1/2 ton) has 'em. Factory. My Dad ordered this truck with this option (he liked the look). JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
