What size wire ?
#2024288
03/04/16 04:03 AM
03/04/16 04:03 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
I have an older 850 DP on my car and I am going to try and lean my transfer slot (idle feed restriction) circuit a small amount and I think I may just use a small piece of wire as this carb has no jets other then main jets. Yes I could modify it but I want to try the wire in the idle restriction to see how it works. But I am not sure how the wire effects it compared to changing the idle restriction jets on newer carbs. So I was wondering if anyone has done this as I know its an older trick and I was curious what size wire anyone who has done this started with. Thanks , Ron
Re: What size wire ?
[Re: 383man]
#2024291
03/04/16 04:13 AM
03/04/16 04:13 AM
Posts: 43,284 Bend,OR USA
Cab_Burge
Do you have a numbered drill bit set that will measure the I.D. of that hole? If so see what size it is now and try and reduce the hole size by 1/4 to 1/2 of what is is now with a small wire, maybe one strand off of a wire brush or wire wheel I started reducing the idle fuel feed and transition fuel feed holes in the Holley Dominator carbs. I use by drilling and tapping those holes for a number 6 brass set screw and then reducing the OEM hole size by a little les than half the I.D., that really helped clean up the AFR at low part throtlle cruise RPMs Before that I had used a small piece of wire in the idle air bleeds to clean up the idle and slow idle speed crusing, that helped also
[Re: 383man]
#2024462
03/04/16 02:13 PM
03/04/16 02:13 PM
Thumperdart
State of confusion
You need to know the size you now have like Cab said to determine how much smaller to go BUT there`s a change needed to the idle bleeds to keep the %`s the same.............
[Re: krautrock]
#2024480
03/04/16 02:51 PM
03/04/16 02:51 PM
Thumperdart
State of confusion
Don`t have exact ratios on bleed to ifr`s as every motor`s different but on my carb I was at .070 ib and .039 ifr`s and went to .067 ib`s and .037 ifr`s and cleaned it up nicely and got rid of a slight lean spot off idle. A smaller bleed provides fuel further in the throttle opening than a larger one and will maintain a signal at a larger throttle opening than the larger bleed. Large=signal sooner.............
[Re: 383man]
#2025483
03/06/16 02:37 AM
03/06/16 02:37 AM
Posts: 5,447 So Cal
Sinitro
So Cal
Ron.. Are U aware that the Quick Fuel Technology metering plates actually have idle restrictor jets.. More $ but far more precise.. Just my $0.02...
[Re: Sinitro]
#2025491
03/06/16 02:50 AM
03/06/16 02:50 AM
Thumperdart
State of confusion
When you can I agree go billet although you still need to drill n tap the ifr`s into the lower position, clean up emulsion etc. but you can do that w/stock blocks as well............
[Re: Sinitro]
#2025594
03/06/16 11:18 AM
03/06/16 11:18 AM
383man
Balt. Md
Ron.. Are U aware that the Quick Fuel Technology metering plates actually have idle restrictor jets.. More $ but far more precise.. Just my $0.02... Yes I know but since cash is tight for me right now I thought I would try this old trick and see how it works. And thanks , Ron
