Re: VIN SWAP ON DASH FOR RESTORATION
[Re: KYLES69RR]
#2024025
03/03/16 08:04 PM
03/03/16 08:04 PM
Posts: 5,886 ohio
ruderunner
ohio
Pads are swappable, no need to touch the Vin.
Angry white pureblood male
[Re: KYLES69RR]
#2024044
03/03/16 08:35 PM
03/03/16 08:35 PM
Posts: 10,141 A Red State
SNK-EYZ
A Red State
When you say "with a cracked dash" are you talking about the dash pad or the actual metal dash frame?
If it's the dash pad, it's a bolt on part and will have no affect on the metal dash frame that the VIN tag is connected to.
If it's the metal dash frame (also a bolt in part), replace it and use the correct style rivets to attach the VIN tag to the replacement metal dash frame.
You're simply replacing a bad part and re-attaching the original VIN tag to the car it came on.
[Re: BDW]
#2024265
03/04/16 02:55 AM
03/04/16 02:55 AM
Posts: 1,396 chicago,il
jaque
chicago,il
Swap away, VIN stays with car. yep spoke to a state deputy sheriff, said just that.. as long as it for that car you can do what you want..
you come here with nothing and leave here with nothing!! enjoy life while on this planet, cuz when youre dead youre dead!!!
[Re: KYLES69RR]
#2024373
03/04/16 11:35 AM
03/04/16 11:35 AM
Posts: 5,138 East Aurora (Buffalo) NY
RoadRunner
I have had several 68 and 69 b-bodies apart. I have never seen the metal frame cracked. Pads, yes. Frame never. I have seen some rust in the corner from leaking windshield. But usually you don't see that until you have the windshield out and seal removed. The VIN is attached to the metal frame. So if replacing the soft vinyl pad, then no need to touch the metal.
With that said, I think all you need to do is replace the pad. there are five speed nuts (stamped steel nuts) that hold it on. A 1/4" ratchet with an assortment of extensions and swivels will allow you to reach them. If I recall, the hardest ones are where the instrument cluster is.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
[Re: Porter67]
#2024399
03/04/16 12:11 PM
03/04/16 12:11 PM
Posts: 5,163 CT
GTX MATT
CT
It might be easier if you posted pics of the cracked dash and exactly what you intend to do.
Then people could give you a better measured response. Yes and please include a picture of the VIN so we can blacklist your car
[Re: 451Mopar]
#2024430
03/04/16 01:08 PM
03/04/16 01:08 PM
Posts: 2,864 Pattison Texas
CSK
Pattison Texas
ECS has what you need to restore the vin tag
[Re: KYLES69RR]
#2024441
03/04/16 01:37 PM
03/04/16 01:37 PM
Posts: 4,740 Florida
BDW
[Re: KYLES69RR]
#2024469
03/04/16 02:28 PM
03/04/16 02:28 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Assuming you actually need to replace the frame and not just the pad; take the window out and do it right.
2 cents,
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
