Aluminum main caps or Billet with a girdle?
#2023920
03/03/16 05:08 PM
03/03/16 05:08 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Just what it says. For the new 499" low deck. Which do you prefer? Half fill also maybe?
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Aluminum main caps or Billet with a girdle?
[Re: Eric]
#2023936
03/03/16 05:34 PM
03/03/16 05:34 PM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I'd do aluminum caps and studs. Nothing else.
[Re: wyoming]
#2024111
03/03/16 10:28 PM
03/03/16 10:28 PM
dartman366
Mt. Vernon, Ohio
Eric, my new 512 will have aluminum cap's,studs and girdle, all BCR stuff, my machinist advised me against any fill in the block.
[Re: JAMESDART]
#2024197
03/04/16 12:35 AM
03/04/16 12:35 AM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
Is the short fill an issue for cooling as street car? I think it is. I had a 500" low deck in my 9 second 69 Dart, after 15 minutes of street cruising my oil would get hot and would idle at 18-20 pounds at a stop light, always made me nervous. Now I have a 500" low deck in my Duster with no filler and it doesn't cook the oil. I think a good oil cooler setup would help tremendously though.
[Re: ProSport]
#2024244
03/04/16 02:22 AM
03/04/16 02:22 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
On my 505 stroker pump gas engine I used the BCR girdle ,aluminum main caps, ARP studs. Block is 1/2 filled. After 8 years of running close to 1,000 1/4 mile hits the block wasn't cracked, no cap walk . If it last another 8 years I'll be to old to get in the car, well maybe out of it.
[Re: rowin4]
#2024667
03/04/16 09:12 PM
03/04/16 09:12 PM
ProSport
Akron, Ohio
On my 505 stroker pump gas engine I used the BCR girdle ,aluminum main caps, ARP studs. Block is 1/2 filled. After 8 years of running close to 1,000 1/4 mile hits the block wasn't cracked, no cap walk . If it last another 8 years I'll be to old to get in the car, well maybe out of it. Sounds like a good setup.
[Re: Eric]
#2024789
03/05/16 12:54 AM
03/05/16 12:54 AM
Superfreak
Superfreak
What happened to the piece that BG built you if you don't mind me asking?
[Re: Eric]
#2024791
03/05/16 01:04 AM
03/05/16 01:04 AM
Eric
Pittsburgh PA
I let someone else try to fix it when the block sprung a leak. Downhill from there. Bob built a nice piece.👍
