10" wide wheel in a 1964/65 B body wheel well #2023357
03/02/16 06:56 PM
03/02/16 06:56 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Ok ,
I know I can run a 8" rim with a 275 tyre .
Can you run a 10" rim with a 275 or 10.5 wide tyre in the stock wheel well and stock width diff ? No spring relocation .
Or even with a 68 diff in a 64/65 B body ?
If so is it a 5.5" back space ?
thanks in advance ,
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: 10" wide wheel in a 1964/65 B body wheel well [Re: tex013] #2023374
03/02/16 07:24 PM
03/02/16 07:24 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I run a 10 inch rim with wide tires on my 65 BS is 4.5.%.5 will almost rub the spring unless spring is inboard.I have a 5.5 BS that I will run when I move my springs.Rocky
Chrysler Firepower
Re: 10" wide wheel in a 1964/65 B body wheel well [Re: therocks] #2023392
03/02/16 08:23 PM
03/02/16 08:23 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
I ran 275/60R15 Radial T/As on 15x10 American Racing wheels in my '64 Polara.
I bought and mounted the wheels and tires first and took out the 8.75" rear. I got a Dana 60 and narrowed it to allow for the stock spring location and the back spacing of the wheels. I don't remember what the measurements were, but it all cleared nicely. I ran the 11.75" disc brakes in front and 10" drums in the rear with a non-power master cylinder. The first rear drums I used were the non-fin drums and when I went to the bigger finned drums, I ran into clearance problems with the leaf springs due to the size of the bell...I had to have the lip of the drums turned off to clear. The car now lives in the Chicago area...I sold it on e-Bay in 2010.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: 10" wide wheel in a 1964/65 B body wheel well [Re: tex013] #2023399
03/02/16 08:32 PM
03/02/16 08:32 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks guys .
If I go there it will be with a 1968 diff , maybe a 5/16" wider per side . I thought with this I would be able to use a 5.5BS 15x10 rim from a 1968 b body . As spring perch width is the same .
Tex
New best MPH 130.32
Re: 10" wide wheel in a 1964/65 B body wheel well [Re: tex013] #2023409
03/02/16 08:53 PM
03/02/16 08:53 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I ran a 285/45-18 in the back of my 65 Belvedere. There was contact on the outside a couple inches up from the opening. The outer wheel house rolls in from the quarter panel. A finely tuned BFH pushed it back out solved the problem.
There's a ton of room between the wheel house and quarter panel so no worries about visible dents.
- Stu Harmon
