Page 7 of 11 1 2 5 6 7 8 9 10 11
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2022863
03/01/16 11:24 PM
03/01/16 11:24 PM
Tacoma, Washington USA
Adam71Charger Offline OP
Bad news though, I removed more bearings and inspected closer. My bearings and crank journals have scratches and a nicks. Gotta take the crank to a local grinder.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: JohnRR] #2022874
03/01/16 11:33 PM
03/01/16 11:33 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Originally Posted By JohnRR
Originally Posted By RS23U1G
Originally Posted By Twostick
Generating higher pressure and running unneeded oil thru the bypass actually generates more heat.
HV...
Higher VOLUME...
Not pressure...
But if one does nothing to increase the flow a hi volume pump does nothing but cycle the excess volume thru the return ... creating heat ... and RAISES the pressure ... because pressure is a restriction to flow ...
I run a STOCK pump on my 505" stroker with a 7qt pan. 75 psi at cold idle, 50 psi hot going down the road and never dips below 25 psi warm. All a high volume pump is good for is sucking the pan dry and robbing horsepower! In fact, the composite gear from Crane that I used with my billet roller cam says NOT to run a high volume pump!
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2022917
03/02/16 12:29 AM
03/02/16 12:29 AM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
It may be a bad hit to your budget but 2 years from now it may pay dividends.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2022947
03/02/16 01:08 AM
03/02/16 01:08 AM
Its gonna set me back a bit but not to bad. a re-ring kit with sealed power bearings and cast rings (with gasket set too) is 250 from mancini. I'm gonna see if I can price out the stuff I need individually from various sources for cheaper. The crank guy charges 25 for polish, 100 for grind.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2022960
03/02/16 01:32 AM
03/02/16 01:32 AM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
You will probably find that a package deal is your best (cheapest) way to go. Years ago I worked at a NAPA store where we occasionally sold a crank kit that was a turned crank with matched rod & main bearings. I am sure that deal is still around at the major stores.
I just tore down a 360 that I intend to build for my daily driver. It had been built before and it's crank has been turned .010 on the mains and still looks good and will polish out. I have not pushed the pistons out yet, they are .040 over so I don't know how much the rod journals have been cut, but I am very hopeful. I bought the core for $100.00 and it came with a truck pan that I need. I will be keeping track of what I spend.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2023018
03/02/16 04:50 AM
03/02/16 04:50 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Get your crank ground and then check out RockAuto for your parts. I've found great deals with quality stuff.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: elmor353] #2023021
03/02/16 05:03 AM
03/02/16 05:03 AM
when you rent the ridge reamer keep it flat against the bore & pull the cutter around with a box wrench as opposed to pushing it (the cutter) ahead of you. Stop often & feel for the amt of ridge left. it will generally not cut even (close tho) so discipline your self to stop when the lowest part of the ridge (least amt of ridge left) is just a hair above flush as you dont want to gouge below. EDIT As you are working around the cyl in a circle change/shift your position often so you are always (pretty much) pulling in a straight line toward you. Gets tough in some of the clocking positions on some of the cyls especially but that is an opportunity to discipline yourself/be a professional. In the car you'd wanna take the hood off but you are ahead of an "over the fender" overhaul cuz the block is already out
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: elmor353] #2023026
03/02/16 05:23 AM
03/02/16 05:23 AM
E
elmor353 Offline
elmor353  Offline
E
A little tip from an engine builder I worked for: after honing and cleaning your block, grab a roll of paper towels and a quart of transmission fluid. Then wipe down each cylinder with trans fluid and keep wiping with clean paper towels till no more dirt shows on the towel. A lot of people wash the bores with hot soapy water, dry them out and call it good. There is ALWAYS left over metal in the bores from honing. This way you know your bores are clean when you assemble your engine.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: elmor353] #2023062
03/02/16 10:23 AM
03/02/16 10:23 AM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
It's a good tip but not a secret.. I've been using that techneque since the peanut man was in the Whitehouse.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: SomeCarGuy] #2023084
03/02/16 11:39 AM
03/02/16 11:39 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Originally Posted By SomeCarGuy
A hv pump is a crutch for a trashed, ragged out engine. Thinking new bearings go hand in hand with one is wrong.
I would agree with you if he was having the crank ground or at least inspected. The journal wears with the bearing, and that says nothing about his cam bearings. He could put it together with the stock pump and see how his oil pressure goes or he could go straight to a hv pump.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: RapidRobert] #2023173
03/02/16 02:38 PM
03/02/16 02:38 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You are too late with this advice, he already took the bore buster to the block ...
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: JohnRR] #2023217
03/02/16 03:37 PM
03/02/16 03:37 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
darn it........ the things we could add to this topic. No wonder the popo couldn't be out ran.
440 and busted
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: 52savoy] #2023273
03/02/16 04:44 PM
03/02/16 04:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
440 and busted
haha
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: 52savoy] #2023333
03/02/16 06:19 PM
03/02/16 06:19 PM
440 and busted
Ok you guys got me worried now, does it look like I reamed to much of the cylinder?
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2023393
03/02/16 08:25 PM
03/02/16 08:25 PM
Elmor that is an excellent reminder on using tranny fluid & yes it does work well. Savoy that is 2 posts in a row from yoou which added nothing (constructive) to the thread & what is (the popo couldn't be outran) that you added to my quote?
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2023398
03/02/16 08:32 PM
03/02/16 08:32 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
440 and busted
Well you could always have the block sleeved... Years ago a friend of mine had a leaking soft plug in his race 440. He fought it for a while and could not get it out (still in the car)...so he figured he could drill through the plug, put a screw in the hole and crank it out. Unfortunately, he went through the cylinder wall with the drill bit and that ended his season. He had a lot invested in that block, so that hole got bored and sleeved.
2008 Honda Element
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2023415
03/02/16 08:57 PM
03/02/16 08:57 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It looks rough but there's no way to tell without being there in person. It will likely be okay as long as there isn't a steep between the work you did and the original bore.
Some folks are pretty sensitive to appearances.
- Stu Harmon
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2023427
03/02/16 09:13 PM
03/02/16 09:13 PM
Ok thanks feets I'll double check every cylinder. It felt uniform when I first checked though. If I did ream slightly to much, will it lose compression?
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2023429
03/02/16 09:18 PM
03/02/16 09:18 PM
PA.
"Little"John
"Little"John
PA.
I wish you lived closer. We could throw it on one of my engine stands and keep each outer company. It would be a fun project.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2023438
03/02/16 09:35 PM
03/02/16 09:35 PM
Same here! I've noticed most of you guys are between Midwest to east coast.
