supercharging a slant 6...hmmmm... #202316
01/23/09 09:57 PM
01/23/09 09:57 PM
Phoenix - surface of the sun
nomore65BelvJim Offline OP
I have a nice running 225 super 6 I plan on dropping in a 72 Demon and I want to put a supercharger on it
NO, not some expensive "kit", NO not a turbo not interested in either at this point. No NOS either!
IF it would work I'd like to use one of those Ford/GM V6 superchargers The size looks good and they all seem to be made for approx. 3.8L engines...225 slant being 3.7L so it seems like a match...of sorts. The big bonus for me is they can be had pretty cheap...$100 and up...I like cheap especially for this project!
I cant find a lot of info out there on this Somebody must have done it already...I'd also like to find some info on the sc itself, requirements for operation, lubrication, etc.
Anybody seen one of these used this way?
Any help is appreciated
generic picture of sc unit...Eaton M90 I believe...
Re: supercharging a slant 6...hmmmm... [Re: nomore65BelvJim] #202317
01/23/09 10:09 PM
01/23/09 10:09 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
I think Aussiespeed was working on a slant intake just to take those little Eaton blowers actually don't think they where ready yet off hand though..
Re: supercharging a slant 6...hmmmm... [Re: nomore65BelvJim] #202318
01/23/09 10:40 PM
01/23/09 10:40 PM
pacific northwest
W
wings471 Offline
wings471  Offline
W
pacific northwest
I would be very interested in a project like that myself 65BelvJim. I'm curious what horse power improvements would be gained with a fairly stock set up. AND...how much $$$ to get there using a factory supercharger. Great idea.
Re: supercharging a slant 6...hmmmm... [Re: wings471] #202319
01/23/09 10:50 PM
01/23/09 10:50 PM
NY NY
3
340duster340 Offline
NY NY
1966 Dart GT ...down to only 1 mopar for the first time in 15 years!
Re: supercharging a slant 6...hmmmm... [Re: nomore65BelvJim] #202320
01/24/09 12:50 AM
01/24/09 12:50 AM
I know a guy in Alberta Canada that did just what you are talking about.He did a blower on a 225 with fuel injection and crank trigger ignition.All in a 1960 Dodge hardtop.Very cool and very nicely done.I spoke to hima at length at a car show a few years ago.Seems to me he had all the info on a webpage too.Maybe off the Slant 6 forum ?
Re: supercharging a slant 6...hmmmm... [Re: OzHemi] #202321
01/24/09 01:51 AM
01/24/09 01:51 AM
yeah Jeff, I saw some info on that intake from Aussiespeed, but its apparently been stalled since middle of last year. Probably more expensive than I want, I can just modify an Offy or Clifford, make an adapter.
this should help you out
http://www.projectplato.com/cars/bigredhome.html
Thanks Mike, some good info there.
Ken I did a search at the slant6 forums and couldnt find much info at all, except about the intake OZ mentioned above. perhaps I am search impaired there
I would like to stay away from fuel injection, crank triggers, etc., keep it super simple...which could help keep it super cheap
Re: supercharging a slant 6...hmmmm... [Re: nomore65BelvJim] #202322
01/24/09 01:59 AM
01/24/09 01:59 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Are you wantint to go efi at the same time? Or mount the s/c somewhere else and pipe into in as a blow-through? I would go right to efi to make it worthwhile, but either would be doable. Making an adapter to bolt onto a 4bbl intake should be easy. Dealing with snout length in terms of aligning the supercharger pulley to your crank pulley will not be so easy. But you can buy snouts for that s/c in different lengths to get the pulley positioned out where you need it. Snout will probably cost as much as the s/c though.
Re: supercharging a slant 6...hmmmm... [Re: DaytonaTurbo] #202323
01/24/09 02:05 AM
01/24/09 02:05 AM
I'd prefer draw through carburated as I have several carbs around that would work. The snout on most of the units I've seen is pretty long so making it line up pully-wise shouldnt be an issue...I hope!
Re: supercharging a slant 6...hmmmm... [Re: nomore65BelvJim] #202324
01/24/09 03:26 AM
01/24/09 03:26 AM
Nampa, ID
None2Slow Offline
None2Slow  Offline
Nampa, ID
Making an adapter shouldn't be to difficult. As for getting the pulleys aligned, you could always use a jackshaft. That's what is done on the LS1 in the corvette. They have a shaft that runs off the belt on the front of the engine and turns the pulley at the back of the engine to turn the SC. Not sure if there is any info, but www.SCCOA.com may have some knowledge. Its a site dedicated to the 3.8 Supercharged Thunderbird's. Many knowledgeable people there as well. They don't tend to do much such as swaps, but a few people have put that SC in VW golfs and such. 1 guy even swapped the 3.8SC engine for an inline turbo 6 from a Supra just to be different. And you can get those SC's from Pick N Pull type yards for as little as $50 or so from 89-95 Tbirds at least.
Re: supercharging a slant 6...hmmmm... [Re: nomore65BelvJim] #202325
01/24/09 10:15 AM
01/24/09 10:15 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I bet that would work well, You could probably even use a 2bbl, although I'd probably use a FoMoCo 500cfm 2bbl. Cool idea and there's plenty of room in that engine bay.
Re: supercharging a slant 6...hmmmm... [Re: Mr.Yuck] #202326
01/24/09 12:19 PM
01/24/09 12:19 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: supercharging a slant 6...hmmmm... [Re: Dodgem] #202327
01/24/09 12:20 PM
01/24/09 12:20 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: supercharging a slant 6...hmmmm... [Re: Dodgem] #202328
01/24/09 01:42 PM
01/24/09 01:42 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
http://www.youtube.com/watch?v=8d-qqeK0B-I
That guy doesn't have a clue....Hits the throttle, and the motor never responds...Sorry, but if your gonna put that in a car, you will be dissappointed. Needs WAAAAAY more tuning.
Re: supercharging a slant 6...hmmmm... [Re: Dragula] #202329
01/24/09 01:47 PM
01/24/09 01:47 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I just found it in a search and thought it was cool!
But I bow to your superior engine building and tuning!
Re: supercharging a slant 6...hmmmm... [Re: nomore65BelvJim] #202330
01/24/09 01:51 PM
01/24/09 01:51 PM
Garden Grove, CA
OzHemi Offline
OzHemi  Offline
Garden Grove, CA
Nothing a and a shouldn't be able to solve then
Re: supercharging a slant 6...hmmmm... [Re: nomore65BelvJim] #202331
01/24/09 04:05 PM
01/24/09 04:05 PM
Taneytown, MD
bigslant6fan Offline
Taneytown, MD
I wonder if the s/c will work with an air-fuel mix?
Re: supercharging a slant 6...hmmmm... [Re: bigslant6fan] #202332
01/24/09 08:08 PM
01/24/09 08:08 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
That question was raised on the Slant board. The most definitive answer was "maybe".
Re: supercharging a slant 6...hmmmm... [Re: slantzilla] #202333
01/24/09 08:20 PM
01/24/09 08:20 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
there was some info on speedtalk.com a while back.maybe post there.
Re: supercharging a slant 6...hmmmm... [Re: slantzilla] #202334
01/25/09 12:56 AM
01/25/09 12:56 AM
I get clearer answers from my wife!
thats for sure one of the things I'll need to find out, along with internal/external lubrication and if intercooler needed type Q's.
thanks for the help so far
Re: supercharging a slant 6...hmmmm... [Re: nomore65BelvJim] #202335
01/25/09 01:04 AM
01/25/09 01:04 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
FWIW the Eaton is internally lubricated, there is a coating on te rotors, I don't know if it will react to gasoline...
