LM2 RPM readout with a Crane box
#2022895
03/02/16 12:08 AM
03/02/16 12:08 AM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Anybody had the pleasure of trying to get a LM2 read RPM with a Crane box? If so...what did you do to get it to read correctly?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: LM2 RPM readout with a Crane box
[Re: jwb123]
#2024126
03/03/16 10:54 PM
03/03/16 10:54 PM
dartman366
Mt. Vernon, Ohio
If the Crane box has a Tach output terminal then plug it in to that, you will need to get the proper analog cord for that, I was trying to use their clamp on inductive pick with mine only to find that it don't work with a MSD and had to wire it to the box.
