The Long Overdue What Will Our 511" Lowdeck Make Thread
#2021828
02/29/16 01:09 PM
02/29/16 01:09 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Okay gang, my 511" low deck is bolted on the dyno waiting on a few small items. We are going to test it with a 250 shot and trim that to 300 after it's dialed in on pump gas. C12 fuel on the plate kit. We will also try two different carbs, one down leg and one annular, both Quickfuel 4150's.
Anyway, I'd love to get the consensus on what you guys think it's going to make!
Here are the specs:
511"
4.375 bore 400 block, aluminum main caps and studs 6.535" Rod, 2.220/.990 Diamond 1.32" CH -12.5cc reverse dome pistons, tool steel pin Ching chong wing wong 4340 crank offset ground to 4.25" stroke, .2.200 rod journal from a Chrysler journal 4.150" crank.
Edelbrock Victor MW heads CNC ported by Hughes and cleaned up a some by me in the chamber and valve job. Manley TI retainers and locks ISKY 9999-RAD springs, 240@2.00" / 740@.750" lift B3R rocker shaft relocation / geometry correction kit. Hughes 1.7 ratio rockers Trend tapered 7/16" push rods
Jones custom roller cam, .740ish lift, 280ish@.050 Isky Red Zone lifters w/ EX-roll option, .180 intake offset due to offset intake rockers due to offset intake ports lol
HV oil pump Milodon 15381 Road Race Pan, external pickup. Milodon Pump cover Hughes hardened shaft and coated gear
Indy 400-2 intake cleaned up a bunch.
4150, 1050 cfm QFT Q-series carburetor
With all of that thanks to everyone that has helped us get this far! I've spent lots of time on the phone with Cab trying to melt his brain down asking questions and hopefully can repay him for his time one day. Mike Jones at Jones Cam Shafts, Micheal at B3R, Jerry at SD Concepts, Monte Smith Racing, and the guys at PSI Springs have helped me learn a ton of knowledge too so if you have the need throw some business there way.
Hopefully we will be ripping power shifts with the G-force by mid summer once the new cage is in.
Re: The Long Overdue What Will Our 511" Lowdeck Make Thread
[Re: Jeremiah]
#2021838
02/29/16 01:26 PM
02/29/16 01:26 PM
Posts: 3,210 robin hood country
deaks
robin hood country
What do you plan to spin it to ? and what is the car combo, gear,converter, tyre, weight etc.
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
[Re: Jeremiah]
#2022686
03/01/16 05:24 PM
03/01/16 05:24 PM
Posts: 345 Nebraska
451Cuda
Nebraska
Indy 400-2 intake cleaned up a bunch. Does this intake outflow the heads?
[Re: 451Cuda]
#2022749
03/01/16 08:05 PM
03/01/16 08:05 PM
Posts: 9,875 Weddington, N.C.
Streetwize
Weddington, N.C.
That motor is A WHOLE LOT like my 517, you have more cam lift and duration but I'm thinking that's offset by a bit more .400-.600 lift CFM's (I got 285 @.400, 335 @ .500 and 361 @ .600) out of my Chapmans. The 400-2 probably flows a little bit more than my Larry Smith ported '337.
I would think you're going to be 745-ish at 6600, if it makes less than that after tuning I'd be surprised. I figure mine is right at 720.
[Re: Jeremiah]
#2022761
03/01/16 08:29 PM
03/01/16 08:29 PM
Posts: 14,499 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Is that the "normal" Lakewood bell housing? Which flywheel are you running?
The 130 tooth flywheel needs the starter mounted using the "inner" bolt holes, which don't really line up with any starter. Provided the headers you're using have enough room to do this, I use the top bolt, then clamp the bottom starter tab to the bell housing with either a vise-grip or c-clamp(I have plenty of room for this with my dyno headers). With the 143 tooth flywheel, I've had no problems just using an old school mopar starter mounted in the "outer" holes.
[Re: Jeremiah]
#2023149
03/02/16 01:45 PM
03/02/16 01:45 PM
fast68plymouth
So. Burlington, Vt.
I agree, it sounds like it was just time to get it home.
After you get it running on your stand it shouldn't be hard to find a dyno service that can make some runs for you.
[Re: 440Jim]
#2023334
03/02/16 06:23 PM
03/02/16 06:23 PM
Streetwize
Weddington, N.C.
Not sure how big the chambers are on the Vics, but My 517 Stage VI worked out to 11.7:1 with a similar D dished piston. I'd imaging this one would be pretty close to that.
