Page 6 of 11 1 2 4 5 6 7 8 10 11
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2021997
02/29/16 06:26 PM
02/29/16 06:26 PM
Tacoma, Washington USA
Adam71Charger Offline OP
Im seeing that 240 grit is the recommended grit for honing for iron rings, is is that what you guys would use?
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2022004
02/29/16 06:41 PM
02/29/16 06:41 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Reuse the bearings....no dice on the hv pump. Not fun w a stock pan and hv pump to look down bout half way through 2nd and not have any OP. YRMV
Ridge ream it, hone, rings and hammer down...
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Von] #2022029
02/29/16 07:28 PM
02/29/16 07:28 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
Definitely get the ridge out of the bores or you may end up having to tear it back down to replace pistons that have broken ring lands. My 77 440 idles in gear, hot, at 65lbs of oil pressure with a stock pump and the original factory bearings. No need for a high volume oil pump. A hone with 240 grit should be fine for cast iron rings. I've seen 180 grit hones used for cast before.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2022054
02/29/16 08:12 PM
02/29/16 08:12 PM
What are the ring groove sizes for my pistons? 5/64" 5/64" 3/16"?
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: SomeCarGuy] #2022492
03/01/16 11:51 AM
03/01/16 11:51 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Originally Posted By SomeCarGuy
I have no idea why the high volume pump idea wont die. With new bearings recommended at the same time no less. shruggy
Because he's slapping new bearings on worn out journals. This is the application hv pumps were intended for.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: pittsburghracer] #2022493
03/01/16 11:52 AM
03/01/16 11:52 AM
Manitoba, Canada
Manitoba, Canada
Originally Posted By pittsburghracer
If there is any ridge at all you can and probably will do damage to the rings. Imagine a brand new ring slamming against it.
I thought about that too, however I had no problems when I threw a new set of rings in my 76 440.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: DaytonaTurbo] #2022575
03/01/16 01:58 PM
03/01/16 01:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
If anything new bearing on a worn journal would potentially restore some clearance, not make it worse.
Everyone puts on a Hi Volume pump because that is the hi performance thing to do.
It will suck a 4qt sump pan dry that is low on oil wink
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: JohnRR] #2022595
03/01/16 02:36 PM
03/01/16 02:36 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
You got that right John. They do more harm than good and rob horsepower too.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2022623
03/01/16 03:37 PM
03/01/16 03:37 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Why would you use a stock pan?
Have a great day
Iowan
"obsolete is neat"
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Iowan] #2022630
03/01/16 03:47 PM
03/01/16 03:47 PM
Budget build. But I am trying to sell or trade my 699 pan to get at least seven quart for mine
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2022656
03/01/16 04:22 PM
03/01/16 04:22 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
If this engine is for a street car, I would use nothing else but a HV oil pump...
If for nothing else, the cooling capability...
Been running one for many years on a street car...
Temp is the enemy on a car that's gonna see extended running time...
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2022658
03/01/16 04:25 PM
03/01/16 04:25 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
The phrase if it ain't broke don't fix it comes to mind here.
You are doing a basic stock spec rebuild here with some minor bolt on improvements. A couple of DIY mods to that stock pan to keep the oil in the sump is all it needs.
As for the HV pump, not likely needed. Here's a test. Use the original pump (after inspection) and make note of your hot oil pressure. It should be in the 55-65 psi range throttled up which is lots for an engine that won't see over 6000 RPM. Pull the relief spring out and shim it with a flat washer. If your hot oil pressure is now higher, the regular volume pump is able to supply more oil than you need.
If it isn't, then the cam bearings are likely worn out. On a low buck engine the easy way to crutch this up is a HV pump.
Kevin
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: RSNOMO] #2022666
03/01/16 04:37 PM
03/01/16 04:37 PM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Generating higher pressure and running unneeded oil thru the bypass actually generates more heat.
Kevin
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Twostick] #2022670
03/01/16 04:42 PM
03/01/16 04:42 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
HV...
Higher VOLUME...
Not pressure...
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Iowan] #2022725
03/01/16 06:54 PM
03/01/16 06:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Because the car is stock looking and a pan that drags on the street if you look at a pothole crosseyed is not an option.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: RSNOMO] #2022727
03/01/16 06:56 PM
03/01/16 06:56 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
HV...
Higher VOLUME...
Not pressure...
But if one does nothing to increase the flow a hi volume pump does nothing but cycle the excess volume thru the return ... creating heat ... and RAISES the pressure ... because pressure is a restriction to flow ...
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: pittsburghracer] #2022736
03/01/16 07:17 PM
03/01/16 07:17 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
Exactly guys. I have no idea why the hv pump idea wont die. With new bearings no less. It has staying power better than the pyramids.
I want my fair share
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: DaytonaTurbo] #2022738
03/01/16 07:22 PM
03/01/16 07:22 PM
SomeCarGuy Offline
SomeCarGuy  Offline
No, that isnt what a hv pump was ever for. New bearings should bring up the pressure with a standard pump. I wouldnt bother changing them unless they were real bad anyway. At that point you'd likely want to polish or cut the journals, which also raises pressure.
A hv pump is a crutch for a trashed, ragged out engine. Thinking new bearings go hand in hand with one is wrong.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: SomeCarGuy] #2022741
03/01/16 07:36 PM
03/01/16 07:36 PM
E
elmor353 Offline
elmor353  Offline
E
I bought a 4oo years ago that was supposedly rebuilt. The oil light would come on at idle. The guy never checked or replaced the cam bearings. Even with an HV pump the light would flicker at idle in gear. I put a HP spring in the HV pump, problem solved. Cam was bouncing around in what was left of the bearings. A year later I went through the engine, new cam bearings, did it right. Not thinking I threw the same pump back on. It was after the 2nd oil filter exploded that I realized what I had done. A good used stock pump cured that. I would only consider using an HV pump if the bearing clearances were huge and if they're more than .003, then the crank needs grinding anyway.
Re: Can I achieve 400hp with a late 70's 440 on a $2000 budget [Re: Adam71Charger] #2022862
03/01/16 11:20 PM
03/01/16 11:20 PM
Alright guys I reamed the ridges off. It left a grainy surface but I think I did it right, my finger nail doesn't catch any sort of Ridge anymore.
