Re: MP STAGE VI vs EDDY 60189
[Re: A/MP]
#2022388
03/01/16 03:08 AM
03/01/16 03:08 AM
Posts: 4,647 aotearoa
rebel
aotearoa
i have a set of MW Stage VI heads, they needed a lot of grinding to make them user friendly. if i had my way again, i'd go for Indy SR's.
[Re: A/MP]
#2022476
03/01/16 11:25 AM
03/01/16 11:25 AM
Posts: 13,377 Marion, South Carolina [><]
an8sec70cuda
If I HAD to choose b/t those 2 heads, I'd go w/ Edelbrock. Why the open 88 cc chamber? Go w/ the closed 84 cc chamber Edelbrocks if you go that route. Better all around. Those Stage VI heads need a ton of work to be useable and make decent power from what I've seen. After you've spent more in them than comparable Indys, the Indy head will still make more power.
My honest opinion...I had a set of Edelbrocks several years ago, then swapped them out for Indy SRs. I'd get some prepped Indys from someone like Dwayne Porter and call it done.
[Re: an8sec70cuda]
#2023193
03/02/16 03:08 PM
03/02/16 03:08 PM
Posts: 75,071 U.S.S.A.
JohnRR
U.S.S.A.
My honest opinion...I had a set of Edelbrocks several years ago, then swapped them out for Indy SRs. I'd get some prepped Indys from someone like Dwayne Porter and call it done. Agreed on all points . The only reason to use the eddy open chamber head is because you have a shortblock with quench dome pistons from an open chamber, iron head build. stage 6's need a lot of work, sometimes they won't even drop on the block dowels. Talk to Dwayne ...
[Re: A/MP]
#2023391
03/02/16 08:19 PM
03/02/16 08:19 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I had a brand new pair of Edelbrock performer rpm's sitting in my bedroom when I found a set of brand new Stage VI heads and intake on ebay that had been fully ported for the same price as the Edelbrock's. I sent the Edelbrock's back and bought the stage VI's. At this point after running them for five years I have to say I don't think my car would be as fast with the Edelbrock's unless I put a bunch of money into them. The only thing that bothers me about the Stage VI is the wet header bolt holes.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2028245
03/10/16 12:39 AM
03/10/16 12:39 AM
Posts: 792 Earth
Rob C
Earth
I had a brand new pair of Edelbrock performer rpm's sitting in my bedroom when I found a set of brand new Stage VI heads and intake on ebay that had been fully ported for the same price as the Edelbrock's. I sent the Edelbrock's back and bought the stage VI's. At this point after running them for five years I have to say I don't think my car would be as fast with the Edelbrock's unless I put a bunch of money into them. The only thing that bothers me about the Stage VI is the wet header bolt holes. I'd say you made out right well with the Stage VI heads since they require a lot of work to get going. Does Dwayne Porter have a CNC program for them? The ones in the MP catalogs are a bit to pricey for my wallet, hence, I go slow. LOL!
[Re: JohnRR]
#2028296
03/10/16 01:56 AM
03/10/16 01:56 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
My honest opinion...I had a set of Edelbrocks several years ago, then swapped them out for Indy SRs. I'd get some prepped Indys from someone like Dwayne Porter and call it done. Agreed on all points . The only reason to use the eddy open chamber head is because you have a shortblock with quench dome pistons from an open chamber, iron head build. stage 6's need a lot of work, sometimes they won't even drop on the block dowels. Talk to Dwayne ... I agree also as thats just what I did. I was an at home porter but I am no pro and my back wont let me bend over cyl heads for long anymore so I called Dwayne Porter and got a set of Indy EZ heads that he just did some mild work on. Bottom line is he does awesome work and he is a pro who flows his heads so he knows what works good better then most all of us. You cant go wrong buying from Dwayne and letting him do his magic on the heads. Ron
[Re: Rob C]
#2028462
03/10/16 12:42 PM
03/10/16 12:42 PM
an8sec70cuda
Dwayne does not CNC heads, he hand ports them...and does some of the nicest work you'll ever see.
[Re: A/MP]
#2028893
03/11/16 12:09 AM
03/11/16 12:09 AM
Posts: 21,080 Niles , Ohio
therocks
Niles , Ohio
Every BB Mopar Ive seen had drains from the factory in the block.Rocky
Chrysler Firepower
