putting engine back in? #202203
01/23/09 07:51 PM
01/23/09 07:51 PM
GoDartGo Offline OP
GoDartGo  Offline OP
Who has stuffed a deep pan'd 360/727TF combo
into an A body with the tranny connected to
the engine..from the top?
As much as I hate to, I'm taking the headers/steering
linkage out to do this.
I'll hang up so you can answer my question.
Re: putting engine back in? [Re: GoDartGo] #202204
01/23/09 07:53 PM
01/23/09 07:53 PM
St Charles MO
70Coronet500Vert Offline
St Charles MO
Take your K-frame out and stuff it in from bottom
No matter how responsible he may seem, never give your gun to a monkey!
1970 Coronet Vert
1972 Charger
1974 Satellite Sebring Plus Sundance
2001 Ram 4x4
2002 Intrepid
2006 300C
Re: putting engine back in? [Re: GoDartGo] #202205
01/23/09 10:02 PM
01/23/09 10:02 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
Jack the rear of the car up really high. Will make it easier to get in. That long tailshaft can wreak havoc.
Re: putting engine back in? [Re: RobX4406] #202206
01/24/09 01:49 PM
01/24/09 01:49 PM
Mechanic Falls, Maine
4BBodies Offline
mopar addict
4BBodies  Offline
mopar addict
Like Bob says, if you can't do it from below, jack the back of the car up as far as you can, put it on jack stands, and get an engine tilter. Best investment I have made in a LONG time! I'd leave the headers in though, unless you are getting rid of them. Just tie them to the sides.
Re: putting engine back in? [Re: 4BBodies] #202207
01/24/09 03:03 PM
01/24/09 03:03 PM
GoDartGo Offline OP
GoDartGo  Offline OP
Thanks guys, I'm leaving the headers in,I think, but I might just take the complete tie rod/draglink/pitman/idler assembly out, so the headers might just come out anyways.
