Re: Stainless brake lines?
[Re: Mr. Smurf]
#2021893
02/29/16 03:12 PM
02/29/16 03:12 PM
Posts: 5,943 ohio
ruderunner
ohio
Bend your own from CuNi line.
Angry white pureblood male
[Re: dogdays]
#2021915
02/29/16 03:49 PM
02/29/16 03:49 PM
Posts: 15,552 Norwich CT USA
moparts
Norwich CT USA
The 90/10 Copper Nickel brake line makes all others obsolete, except for points restorations.
R. True, BUT it is a lot softer and I have problems with the flare ends braking off, on my off road Willys Wagon. There is a lot of vibration on the Willys wagon.
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: HEMICUDA]
#2022002
02/29/16 06:40 PM
02/29/16 06:40 PM
Posts: 993 Mid Michigan
Mr. Smurf
Mid Michigan
Call Bob at Finelines (330-335-5000 x11), he will probably do it for you. Talked to Mike, they DO stock them and they are on the way. Thanks. Ed
[Re: Mr. Smurf]
#2022005
02/29/16 06:43 PM
02/29/16 06:43 PM
Posts: 1,923 Medina, Ohio
HEMICUDA
Medina, Ohio
Call Bob at Finelines (330-335-5000 x11), he will probably do it for you. Talked to Mike, they DO stock them and they are on the way. Thanks. Ed How about that.
[Re: Mr. Smurf]
#2022119
02/29/16 09:37 PM
02/29/16 09:37 PM
Posts: 5,943 ohio
ruderunner
ohio
Tom, you need to secure your lines better.
Even steel lines will break from vibration.
[Re: Mr. Smurf]
#2022154
02/29/16 10:24 PM
02/29/16 10:24 PM
Posts: 1,107 Massillon, Ohio
cudatom
Massillon, Ohio
I got mine for the 67 from Right Stuff Detailing. Everything installed w/o any issues.
Ok
