in my 2004 wix master catalog, there was a magnetic in line transmission filter listed: pn 58964. the description states it as a double-action, full flow filter down to 25 micron size particles. also states if filter becomes plugged, it resumes full flow thru a pressure relief valve. it handles up to 200lbs pressure, 350*f, and removes over 95% of all magnetic impurities introduced into the trans fluid. to be installed in the rear line on 904/727 transmissions. can also be used on power steering return[low pressure side] lines. i'm not sure if the pn is current, or has been superseded. hope this helps.
