Extra long crank bolt?
#2021208
02/28/16 12:40 PM
02/28/16 12:40 PM
Posts: 1,532 off the grid
340B5
off the grid
While assembling the front end of my engine last night, the crank bolt got soft going in. Come to find out I stripped the last few threads off the bolt. Of course that sinking feeling sets in w/ visions of pulling the engine and complete disassembly and then finding a repair shop for the crank.
After inspection the crank is fine; it was just the bolt. I found a new bolt in my stash of parts and reluctantly used it.
The factory bolt doesn't go in very far w/ a fluid damper and I couldn't find anything online that was longer than 2.25. Do I just need to go to Fastenall and buy a bolt or does someone make one for a Mopar crank?
At this point I'm just really glad the bolt was gr5 and the crank is made of 4340.
Yeah, it's got a smallblock.
Re: Extra long crank bolt?
[Re: 340B5]
#2021209
02/28/16 12:50 PM
02/28/16 12:50 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
440Source has several listed. They show the factory bolt at 1.25". I can't see why you would need anything longer than 2.25". Make sure you don't bottom it out in the crank threads.
[image][/image]
[Re: sgcuda]
#2021230
02/28/16 01:34 PM
02/28/16 01:34 PM
340B5
off the grid
440Source has several listed. They show the factory bolt at 1.25". I can't see why you would need anything longer than 2.25". Make sure you don't bottom it out in the crank threads. I checked that. I'm a long way from bottoming.
[Re: 340B5]
#2021263
02/28/16 02:20 PM
02/28/16 02:20 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I bought my grade 8 from Tractor Supply.
[Re: pittsburghracer]
#2021299
02/28/16 03:03 PM
02/28/16 03:03 PM
340B5
off the grid
My inner gearhead wants to buy a slightly longer bolt, then gun-drill it. Seems like useless weight being it doesn't hold much.
[Re: 340B5]
#2021315
02/28/16 03:22 PM
02/28/16 03:22 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
I recall that for the Fluidamper you use a small block bolt. Much longer than a stock BB bolt. I switched to ARP bolts and I think their BB bolts are a bit longer than stock but can't say for sure.
[Re: 340B5]
#2021347
02/28/16 03:49 PM
02/28/16 03:49 PM
Posts: 19,376 Las Vegas
Al_Alguire
Las Vegas
Just buy a grade 8 bolt from a good hardware store.
[Re: Al_Alguire]
#2021443
02/28/16 06:51 PM
02/28/16 06:51 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
Just buy a grade 8 bolt from a good hardware store. i got mine at Ace hardware,grade 8.
[Re: 340B5]
#2021780
02/29/16 11:08 AM
02/29/16 11:08 AM
markz528
Morrow, OH
So for those of you that just buy a bolt what do you do for a washer? That washer is as critical to proper fastening as the bolt itself. That's why I like the ARP so much. Good hardened washer that does not distort.
[Re: 340B5]
#2021790
02/29/16 11:55 AM
02/29/16 11:55 AM
Posts: 12,588 Great Neck,LI,new york
hemi-itis
I also got an xtra long one with a nut and extra washers.I use that as an installation tool.
