Page 15 of 20 1 2 13 14 15 16 17 19 20
Re: Moparts official power adder thread [Re: tboomer] #2302784
05/11/17 11:27 AM
05/11/17 11:27 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
Question about progressive controllers...
I realize that I should probably pull timing out to manage traction after the hit, but this is just a simple street car with a small plate kit. I am running radials, and track prep is not the greatest, when I have it come on right away, it would spin for 30 ft or so. I have a NOS mini progressive on the car, would it be worth it to try to delay, or progress the hit? The track is normally packed, I'm lucky to get 2-3 passes in, so I'd like to get an idea of where I should start, then I can dial it in from there.
I should probably upgrade the rancho shocks on the back, but I'd like to work with what I have for now. I think I might also go back to slicks just because of the quality of track prep here...
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: Moparts official power adder thread [Re: tboomer] #2302880
05/11/17 03:16 PM
05/11/17 03:16 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
I had a friend that was running deep 9s in the 80s that would tune his hit with different length hoses between the plate and solenoids. Looked kinda goofy with a coiled up hose, but he would always get that car down the track. He had several hose sets that were staggered to sharpen, or soften the hit.
Re: Moparts official power adder thread [Re: tboomer] #2302934
05/11/17 05:18 PM
05/11/17 05:18 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
hmm, can't get much simpler than that...
I did do that on another car actually, part by design, part by accident. The N2O noid was under the dash, then I had a ~2' line running through the firewall, same pill in that car hit much softer.
Re: Moparts official power adder thread [Re: OUTLAWD] #2302942
05/11/17 05:38 PM
05/11/17 05:38 PM
Blue Ridge, VA
Plumb Wired Offline
Plumb Wired  Offline
Blue Ridge, VA
What type ignition box do you have? If MSD programmable use launch retard or gear retard. If you decide to use a progressive I suggest the Leash progressive, simple to wire and use.
RIP Monte Smith
aka: OutlawFish
'98 Bickel Dodge Dakota PST
Re: Moparts official power adder thread [Re: Plumb Wired] #2303137
05/12/17 12:14 AM
05/12/17 12:14 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
This is the one I bought but I have LOTS to learn.
I should have the heads on this weekend and hopefully ready to start making some hits real soon.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Moparts official power adder thread [Re: n20mstr] #2304342
05/14/17 03:00 PM
05/14/17 03:00 PM
NY
challenger451ci Offline
NY
Originally Posted By n20mstr
Originally Posted By challenger451ci
That's makin time! I'm hoping for .50's this year with my barge. I think it's gonna need a little more jet depending how early I can get it all in.
Here is a Monte trick, hit it as hard as you can for the first two tenths, then pull your launch timing out. Monte said, everything dead hooks for two tenths...
I've been thinking about this a bit...He was talking about timing that you'd pull in addition to what you pull for the nitrous(step retard), right? The car does fall on it's face if the initial progressive is set too low on the off chance I'm trying to get it down bare asphalt. Probably because I'm pulling all the timing at the hit, then ramping any launch retard back in over time. It's a balance between hitting the tires hard enough and keeping it planted, especially on an untreated surface.
Re: Moparts official power adder thread [Re: tboomer] #2304373
05/14/17 03:41 PM
05/14/17 03:41 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
I started doing the tip that Monte told Tony and then Tony told me. RESULTS!! it works great and is way faster than just a basic ramp
Re: Moparts official power adder thread [Re: tboomer] #2304481
05/14/17 08:01 PM
05/14/17 08:01 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
A tire needs to be hit and held there to work, especially a radial or a slick on a marginal surface. Hit it hard and hold the tire down with the shock. So....hit it hard but what works well is to hit if for a tenth or two, then pull your launch retard and ramp it in. This helps hit the tire, keeping it there is the job of your shock. To go "fast" you need a good double adj shock. Tight compression keeps the tire planted. What also helps a lot is keeping the front suspension off the limiter. That's either a lot of travel or a tight shock ext setting or a combination of both.
....BAD A$$ STREET CAR.....
Re: Moparts official power adder thread [Re: n20mstr] #2304563
05/14/17 10:43 PM
05/14/17 10:43 PM
NY
NY
Good info! Thanks for the help! I finally broke down and bought a set of Viking DA's all around. Can't wait to get them on the car and start playing around. I really only got one hit on the new motor last year so this is going to be a learning curve for me.
Re: Moparts official power adder thread [Re: tboomer] #2318961
06/10/17 02:33 PM
06/10/17 02:33 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I looked at the Vikings, as I feel I need more control in the rear, and to slow the front down, but that will have to be next years upgrade.
Re: Moparts official power adder thread [Re: OUTLAWD] #2322499
06/17/17 03:44 AM
06/17/17 03:44 AM
Granbury TX
Prochargedmopar Offline
Granbury TX
Excited to be un-boxing my newly acquired power adder.
78/75 Billet .96ar T4 turbo.
"Old" member Registered: Sep 2001
Lost my credentials, I'm Back!! LOL
71 Ply Satellite Procharged
73 Dodge Dart Swinger
73 Ford F-100 390/Sniper efi/back to carb
01 Town and Country Limited
08 Dodge 2500 6.7 5" Deleted
02 Mercedes C230K
19 Camry
Re: Moparts official power adder thread [Re: tboomer] #2326303
06/25/17 03:17 AM
06/25/17 03:17 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Wish you were here Monte. I could really use your help
Re: Moparts official power adder thread [Re: FastmOp] #2330317
07/02/17 07:33 PM
07/02/17 07:33 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Which procharger for a 383 or 400 stroker at around 500 cubes on pump gas?
I am thinking F1R, but want to here from you guys..
Re: Moparts official power adder thread [Re: Dragula] #2334680
07/10/17 01:36 PM
07/10/17 01:36 PM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
http://www.hotrod.com/articles/mopp-0604-440-mopar-engine-build/
Me Thinks F1R...
As BigTime
Re: Moparts official power adder thread [Re: tboomer] #2335120
07/11/17 01:23 AM
07/11/17 01:23 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Does Tony Russo still post here or did the purple people run him off??
Re: Moparts official power adder thread [Re: SpareParts] #2335653
07/12/17 12:26 AM
07/12/17 12:26 AM
N
n20mstr Offline
n20mstr  Offline
N
Lmao !
Occasionally lurking between the constant bolt turning
Re: Moparts official power adder thread [Re: n20mstr] #2337534
07/15/17 07:45 PM
07/15/17 07:45 PM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
Lmao !
Hey bud!! Hope all is going well. Battling a nitrous shortage here. And messed up some stuff on a big wheelie but it's running good
Re: Moparts official power adder thread [Re: SpareParts] #2337602
07/15/17 10:57 PM
07/15/17 10:57 PM
N
n20mstr Offline
n20mstr  Offline
N
Ran a 5.40 @ 138.96 on 4 cyl
I'm getting good at cyl head R&I
Re: Moparts official power adder thread [Re: n20mstr] #2338844
07/18/17 01:52 AM
07/18/17 01:52 AM
Janesville, WI
SpareParts Offline
SpareParts  Offline
Janesville, WI
How did you go about this discovery? That's still fast as hell
Re: Moparts official power adder thread [Re: SpareParts] #2340686
07/20/17 11:54 PM
07/20/17 11:54 PM
N
n20mstr Offline
n20mstr  Offline
N
Ok, just one nipped piston, and some other issues. Changed the carb and it's real fat. Wire for my rpm switch for electric shifter fell out of the msd tach conn/output, banged the limiter. Got all the parts and ready to start reassembling tomorrow . Hope to make a decent showing at monster Mopar next week.
