Where to buy E-85 Carbs! #202098
01/23/09 04:06 PM
01/23/09 04:06 PM
Stockholm,SWEDEN
The Nutcracker Offline OP
Stockholm,SWEDEN
Any good vendors out there for E-85 carbs?
498 stroker now running an 1050 Dominator.
-70 Cuda,-65 Valiant,-66 Valiant,-62 FED
Re: Where to buy E-85 Carbs! [Re: The Nutcracker] #202099
01/23/09 04:49 PM
01/23/09 04:49 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Quick Fuel, you might want to talk to them to get
the proper size carb. I sent them my 1050 dom to
re-work to a E-85, its been great
http://www.quickfueltechnology.com/home_2.htm
Re: Where to buy E-85 Carbs! [Re: The Nutcracker] #202100
01/23/09 05:07 PM
01/23/09 05:07 PM
we have the Quick Fuel E-85 1050 carbs as well as the conversion kits for the 1050 Dominator.
Re: Where to buy E-85 Carbs! #202101
01/24/09 11:11 AM
01/24/09 11:11 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Now the big question was their any performance improvement going from gas to E-85 or just $$$.
Might bump my compression and convert my old dominator. How much did they charge to do the conversion
found this
QFT-34-45E85
Re: Where to buy E-85 Carbs! [Re: Dodgem] #202102
01/24/09 11:55 AM
01/24/09 11:55 AM
MR_P_BODY Offline
MR_P_BODY  Offline
found this
QFT-34-45E85
I'm not done tuning on my set up but with just the
jetting my car is the same(to the hundredth) and I
still havent dialed up timing yet. The big thing
about the E-85 is cost and cooling. It cost me about
1/4 of race fuel even with the increase of volume used.
And the side effect of the E-85 is that it runs cooler
in the engine
Re: Where to buy E-85 Carbs! [Re: MR_P_BODY] #202103
01/24/09 12:28 PM
01/24/09 12:28 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Thanks Kinda what I figured but when I do another 542 I think I'll go 13 to 1 and run E-85??
The cool think at the track will be a real bonus!!
Re: Where to buy E-85 Carbs! [Re: Dodgem] #202104
01/24/09 12:49 PM
01/24/09 12:49 PM
Oklahoma
hemiiroc Offline
hemiiroc  Offline
Oklahoma
Pro Systems can do then.
Re: Where to buy E-85 Carbs! [Re: Dodgem] #202105
01/24/09 10:16 PM
01/24/09 10:16 PM
NC
440Jim Offline
440Jim  Offline
NC
found this
QFT-34-45E85
How do you change the boosters in a Dominator carb? What tools do you need? I see that kit comes with new boosters.
Re: Where to buy E-85 Carbs! [Re: 440Jim] #202106
01/24/09 11:35 PM
01/24/09 11:35 PM
New Lenox IL
cudadon Offline
cudadon  Offline
New Lenox IL
found this
QFT-34-45E85
Jim the boosters are held in by hollow pins that you use a screw to pull them out. Then tap in the new pins after you slide the boosters in place.
I see they include new pins in the bag next to the upper lefthand corner of the gaskets.
It's easy to do, and the boosters align themselves by the slots in the mainbody. Don
Re: Where to buy E-85 Carbs! [Re: cudadon] #202107
01/25/09 11:30 AM
01/25/09 11:30 AM
NC
440Jim Offline
440Jim  Offline
NC
Thanks,
That is much easier than a Holley 4150 carb. Those have a swedge that needs a special tool to align and hold the booster, while expanding the insert.
