Innovate wideband gauge #2020807
02/27/16 04:17 PM
02/27/16 04:17 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
I'm thinking of purchasing a gauge but not sure what to get, I need something simple.
Any suggestions?
Re: Innovate wideband gauge [Re: RV2] #2020811
02/27/16 04:21 PM
02/27/16 04:21 PM
Taxes & Virus's R-US, NY
Dragula Online content
Dragula  Online Content
Summit uses the same gauge, just $10 cheaper...I use one, and man, it is a blessing for tuning a carb.
http://www.summitracing.com/parts/sum-g2997
Re: Innovate wideband gauge [Re: Dragula] #2020907
02/27/16 08:37 PM
02/27/16 08:37 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
If you go on Ebay you can find an Innovate basic unit with the sensor for under $150.00 twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Innovate wideband gauge [Re: RV2] #2021215
02/28/16 01:04 PM
02/28/16 01:04 PM
Az
Crizila Offline
Crizila  Offline
Az
Bought my basic innovate system through Summit. Comes with a very easy to read digital "Summit" gauge.
Fastest 300
Re: Innovate wideband gauge [Re: RV2] #2021787
02/29/16 11:46 AM
02/29/16 11:46 AM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Innovate LC-1 with an analog gauge. It doesn't datalog but it will give you a readout as you drive. Great tuning tool, I wouldn't be without one.
Re: Innovate wideband gauge [Re: RV2] #2021881
02/29/16 02:53 PM
02/29/16 02:53 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I use an LC1 as a wide band adapter on my Holley EFI so I datalog thru the ECM but the LC1 can datalog to a laptop via LogWorks.
Kevin
Re: Innovate wideband gauge [Re: Twostick] #2021888
02/29/16 03:05 PM
02/29/16 03:05 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
LC-1 user here also, Simple, easy to use setup.
The only Carbs I care about are under the hood!
Re: Innovate wideband gauge [Re: Azzkikrcuda] #2021917
02/29/16 03:56 PM
02/29/16 03:56 PM
Carson City, Nevada
Biginchmopar Offline
Carson City, Nevada
I use this one and it works great!
I thought I knew how to tune carbs but I learned a lot by buying this gauge.
http://www.innovatemotorsports.com/products/MTXL.php
beer
Re: Innovate wideband gauge [Re: RV2] #2022237
02/29/16 11:53 PM
02/29/16 11:53 PM
Covington Georgia
RV2 Offline OP
RV2  Offline OP
Covington Georgia
Thanks guys
Re: Innovate wideband gauge [Re: RV2] #2022342
03/01/16 01:39 AM
03/01/16 01:39 AM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I have an lm2. It is ok....not great by anymeans.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
