6 Pack Carbs (Need HELP Decoding) #202020
01/23/09 02:34 PM
01/23/09 02:34 PM
70mopar Offline OP
mopar addict
70mopar  Offline OP
mopar addict
Ok , I have these 3 (set/I think) of 6 Pack Carbs. Can anyone give me any info on how to decode..
Carb # has #'s 3019 on back with LIST 4383 under the top #'s / ex ------------>
3019
LIST 4383
Carb # 2 has #'s ---------->>
3249
LIST 4382
Carb # 3 has #'s ------------>>
3389
LIST 4375
Any info on these carbs would be helpful..? Please advise..
Cheers , Jeff
Re: 6 Pack Carbs (Need HELP Decoding) [Re: 70mopar] #202021
01/23/09 02:36 PM
01/23/09 02:36 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
70 440 4 speed carbs
4382 is front, 4375 center, 4383 rear all built nov dec 69 dan
Re: 6 Pack Carbs (Need HELP Decoding) [Re: ph23vo] #202022
01/23/09 02:43 PM
01/23/09 02:43 PM
70mopar Offline OP
mopar addict
70mopar  Offline OP
mopar addict
Wow , That was awesome & a fast response.
So am I safe to assume this is a matching set.?
*I know this is not the correct section but aprox what are all 3 carbs worth as a set.? Carbs appear to be in good condition & all diaphrams sound good.
Cheers , Jeff
Re: 6 Pack Carbs (Need HELP Decoding) [Re: 70mopar] #202023
01/23/09 02:59 PM
01/23/09 02:59 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
its a set anyway date codes are kinda spread out 301 is late oct and the last one is dec... probably were originally a set though... good luck dan
