Header Help #201944
01/23/09 01:04 PM
01/23/09 01:04 PM
Brea, Ca
Dart Racer Offline OP
Brea, Ca
I just bought a set of TTi headers for my Dart and the flange hits the ARP head studs. TTI says my warranty is void if I grind on them and they don't make any that fit ARP head studs.
So do I grind away or does somebody else make headers that fit a 62 B Body with a 440?
Re: Header Help [Re: Dart Racer] #201945
01/23/09 01:09 PM
01/23/09 01:09 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Could you cut the studs down to clear
Re: Header Help [Re: Dart Racer] #201946
01/23/09 01:23 PM
01/23/09 01:23 PM
Q
Quicktree Offline
Quicktree  Offline
Q
what warranty when you fire them up the warranty is gone anyway. unless you want to pay a restocking fee bla bla bla. grind away and make them fit.
Re: Header Help [Re: Quicktree] #201947
01/23/09 01:27 PM
01/23/09 01:27 PM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Double up on the header gaskets and see if you get clearance. Or swap to a different head fastener.
Re: Header Help [Re: WILD BILL] #201948
01/23/09 01:34 PM
01/23/09 01:34 PM
Las Vegas NV
moparmanjames Offline
Las Vegas NV
Yeah this is what I have done in the past. I have also ground on the flanges as well.
Do what you gotta do man.
Re: Header Help - Headers now on!!!! [Re: Dart Racer] #201949
01/24/09 10:28 PM
01/24/09 10:28 PM
Brea, Ca
Brea, Ca
Well I took your advice and ground off the top of the studs and viola; headers fit with no further grinding on the header. They are TTi's and fit just perfectly!!!! Just need to reroute the starter wires and good to go.
Thanks all for you advice.
