499 c.i. RB main bearing wear (pics) #2019433
02/25/16 01:39 PM
02/25/16 01:39 PM
bigfork mn
dragram440 Offline OP
bigfork mn
Can anyone tell me why the main bearing on my 499 rb look like this? It has 440 source billet steel main caps and ARP main studs. My machine shop fitted the main caps and line bored the mains. The bearings has .002 clearance when Installed.
67' charger 499 RB 10.57 at 127
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019443
02/25/16 02:00 PM
02/25/16 02:00 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
Looks like de-lamination of the top layer. I would want the clearance at .003-.0035. What assembly lube?
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019447
02/25/16 02:05 PM
02/25/16 02:05 PM
new york usa
P
pattyboy 572 Offline
P
new york usa
http://kingbearings.com/files/Engine_Bearing_Failures_and_How_to_Avoid_Them.pdf read this info poor balance job, tight clearances,oil break down (alky motor,e-85) etc.
Re: 499 c.i. RB main bearing wear (pics) [Re: pattyboy 572] #2019458
02/25/16 02:23 PM
02/25/16 02:23 PM
Weddington, N.C.
Streetwize Offline
Streetwize  Offline
Weddington, N.C.
.002 is pretty tight install clearance for a main bearing IMO twocents Cold starts alone (getting the oil there) can play havoc with that tight a clearance. .002" is more appropriate for a rod Bearing IMHO, I typically run .003"-.0035" on a 2.625-2.75" Main bearing.
WIZE
In Car:
Re: 499 c.i. RB main bearing wear (pics) [Re: Streetwize] #2019462
02/25/16 02:26 PM
02/25/16 02:26 PM
an8sec70cuda Offline
iagree Needs more clearance. Get around .003"+
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019465
02/25/16 02:29 PM
02/25/16 02:29 PM
bigfork mn
bigfork mn
Thanks so much for the link, My bearings definately have fatigue overlay. What would cause this. I was supprised how bad the oil looked in the bottom of the pan. There was a little sludge type residue in the bottom of the pan after roughly 100 passes. Could fuel contaminated oil be doing this to the bearings? I'm thinking I need to change the oil more often. I have been running valvoline vr1 20w50 oil. With .002 clearance on the main and rod bearings should I be running a thinner oil? I think I will also switch to synthetic. Any other thoughts would be appreciated. Thanks for the help.
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019469
02/25/16 02:34 PM
02/25/16 02:34 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Agreed on too tight and 20w50 is WAY too thick and I don`t run that in anything ever even at my .032+ main clearances and get away w/5w30-10w30 oil forever.............
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019470
02/25/16 02:36 PM
02/25/16 02:36 PM
Is the sludge possibly asembly and ARP bolt lube? I cringe every time when I see guys on here advising running tight bearing clearances like yours on here tsk Those bearings look like they have had the crank almost wiping up against the bearings tskNot enough bearing to crank clearances shruggy I run .003+ on both rods and mains and I always run full groove main bearings with light weight oil, 5W20Wt with those clearances up
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019487
02/25/16 02:49 PM
02/25/16 02:49 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Looks like fuel contamination and not a clearance issue.We see that a lot with engines that have fuel or coolant getting into the oil.What does the cylinder walls and piston skirts look like?
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019489
02/25/16 02:50 PM
02/25/16 02:50 PM
bigfork mn
bigfork mn
This engine has deffinately had some cold weather start up also. Would I be ok running thinner oil with this clearance? Also these were clevite bearings I believe and the new ones I installed last night were king. I don't have the pistons in yet so it wouldn't be hard to change the mains now if need be.
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019491
02/25/16 02:52 PM
02/25/16 02:52 PM
bigfork mn
bigfork mn
The cyl walls and piston skirts had a little very light scuffing. I thought that was maybe from running no air filter and it can get a little dusty at the track.
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019560
02/25/16 04:39 PM
02/25/16 04:39 PM
bigfork mn
bigfork mn
http://www.summitracing.com/parts/kgb-mb5116hp
These are the new bearings I went with.
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019664
02/25/16 07:39 PM
02/25/16 07:39 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Interesting, my #2,4 mains looked like yours. It appears that one of your bearings shows the flaking only on one side, mine look like that. I was running .027"-.028" clearance which I felt was tight. My oil is 5w30 Royal Purple. Rod bearings (.0032") look perfect. #1,3,5 look decent. My feeling is at my power level the crank may be flexing. Block is a Mega-block so the the center bearings are cross bolted. We opened the line hone for more clearance, we'll see the next bearing check.
Doug
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019701
02/25/16 08:20 PM
02/25/16 08:20 PM
bigfork mn
bigfork mn
These were also the worst ones. The other three don't really show that fatigue coating. They are all the same clearance.
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019720
02/25/16 08:34 PM
02/25/16 08:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Were these #2,4?
Doug
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019862
02/25/16 11:34 PM
02/25/16 11:34 PM
Why would you switch from a 3/4 groove main bearing to a 1/2 grove main bearing on a motor that will see north of 5000 RPM regularly? confused
I like my race engine rods to have oil pressure all the time, not 3/4 or 1/2 time twocents
We're nor racing SB Chevys with little tiny rod journals tsk They have a completely different oiling system so the early SB motors could get away with low oil pressure and oiling the rods 1/2 time until they started making a hoop of HP work
I hope you will reconsider on your main bearing type choice luck
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019907
02/26/16 12:31 AM
02/26/16 12:31 AM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
How was the .002 clearance determined? Measuring bore with bearing torqued? and measuring crank? Plasti Gauge?
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2019920
02/26/16 12:46 AM
02/26/16 12:46 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
20-50 is not too thick..........I use Valvoline VR-1 20-50 all the time and never have any issues with it, but I don't run .002 on the mains either
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2020073
02/26/16 11:52 AM
02/26/16 11:52 AM
bigfork mn
bigfork mn
Ok so I didn't realize the new bearings were a 1/2 groove rather then 3/4. I measured the bearing clearance with plasti gauge. So now Im just not sure what to do. Do I pull it apart and change the bearings? Just looking through summit I dont see any King 3/4 or full groove bearings. Does anyone know a part number on them? I just did a quick serch befor i ordered the bearings and from what I saw on here most said they recommended king bearings.
Re: 499 c.i. RB main bearing wear (pics) [Re: dragram440] #2020197
02/26/16 02:09 PM
02/26/16 02:09 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Either get or have someone come by w/id mics or at least snap gauges and try to see what that gets ya............
