Re: Indy Ez-1 headers
[Re: Stanton]
#2021082
02/28/16 01:56 AM
02/28/16 01:56 AM
Posts: 27,421 Balt. Md
383man
Balt. Md
The EZ heads have the angled plug like the Eddy RPM heads do so you just want to be sure what header you use will work with the angled plugs. Myself I use the TTI which I bought in the standard nickel coating and they were $691.00 about 5 years ago. I know Gus on here uses Doug's on his eng with EZ heads and as far as I know they fit and work fine on the EZ heads and Gus talks very highly of his Doug headers so I would say he is very pleased with them. I really like my TTI headers but I believe the Doug's are a little cheaper then the TTI's. I know the TTI's are good quality since I have them and from what I hear the Doug's are also good quality like the TTI's but myself I have not used the Doug's. Ron
