Holley Dual feed fuel line OEM look?? #2018842
02/24/16 04:36 PM
02/24/16 04:36 PM
Wahoo Nebr
vette1986 Offline OP
Wahoo Nebr
I am putting a 4150 holley on my charger and want the "OE" look of fuel lines not the chrome ones that seem to be the only ones I can find. Anyone know a duel feed fuel line for a holley 4150 that has a factory look? I would assume there are some out there but I can't seem to find them. Thanks
1969.5 A12 Bee EV2
1971 Charger RT
1973 Duster tubbed 500 low deck 10.90 monster
3 440 polara vert projects
Re: Holley Dual feed fuel line OEM look?? [Re: vette1986] #2019073
02/24/16 09:35 PM
02/24/16 09:35 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
There was a company called Fabulous Fabrications (303-666-9882) that use to sell them but I don't know if they are still in business. If you have a double flare tool you can make them yourself pretty easily.
Re: Holley Dual feed fuel line OEM look?? [Re: vette1986] #2019108
02/24/16 10:33 PM
02/24/16 10:33 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
Re: Holley Dual feed fuel line OEM look?? [Re: vette1986] #2019166
02/24/16 11:43 PM
02/24/16 11:43 PM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
I tried making a set of lines but my bender kept kinking the tube, and I only had a T fitting, but I can see if I can buy a fitting like this one and fab something up for it.
Mike, I even thought about cutting and brazing something together but I think that might not be as easy.
Kasey
Re: Holley Dual feed fuel line OEM look?? [Re: Moparnut426] #2019343
02/25/16 10:43 AM
02/25/16 10:43 AM
Jacksonville Fl
70BigBlockSE Offline
Jacksonville Fl
I used the Camaro fitting and bent my own. Pretty happy with it. The fitting comes in either 3/8 in and out or 3/8 input and 5/16 outs
Re: Holley Dual feed fuel line OEM look?? [Re: 70BigBlockSE] #2019354
02/25/16 10:58 AM
02/25/16 10:58 AM
Wahoo Nebr
Wahoo Nebr
We need a 3/8 fitting. Where did you get yours? I think Kasey can bend up the tubing if we can get the fitting. Thanks
1969.5 A12 Bee EV2
1971 Charger RT
Re: Holley Dual feed fuel line OEM look?? [Re: vette1986] #2019361
02/25/16 11:12 AM
02/25/16 11:12 AM
Jacksonville Fl
Jacksonville Fl
Right Stuff Detailing PN RSBB06 'Y' Block, 3/8 x 3/8 x 3/8 from Jegs or Summit, a little over $20
Re: Holley Dual feed fuel line OEM look?? [Re: vette1986] #2019410
02/25/16 12:42 PM
02/25/16 12:42 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
I had a partial 6bbl fuel line kit laying around. I used the line from the pump to the first T, and the s shaped tube to the front inlet. I bought a straight line from NAPA and bent it to get to the rear fitting.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
