Re-locating a power steering pump ? #2018674
02/24/16 11:34 AM
02/24/16 11:34 AM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
Anyone ever move the location of a power steering pump on a small block ? I have a Saginaw pump on a 1973 318 that I need to move up a few inches.
Re: Re-locating a power steering pump ? [Re: 2abodymcodes] #2018736
02/24/16 01:33 PM
02/24/16 01:33 PM
wooster ohio
3
3csalvage Offline
3csalvage  Offline
wooster ohio
iirc 70'sSnow Commander trucks used brackets for the plow pump that may work for that, but it has been years since I had any.
Re: Re-locating a power steering pump ? [Re: 3csalvage] #2018795
02/24/16 03:27 PM
02/24/16 03:27 PM
Mid Michigan
Mr. Smurf Offline
Mr. Smurf  Offline
Mid Michigan
Those brackets moved the pump to the top center of the engine....probably farther than he wants to go.
Ed
Re: Re-locating a power steering pump ? [Re: Mr. Smurf] #2019033
02/24/16 08:42 PM
02/24/16 08:42 PM
wooster ohio
3
3csalvage Offline
3csalvage  Offline
wooster ohio
I was thinking they were straight above the ps pump but as I said its been years ago.
Re: Re-locating a power steering pump ? [Re: 3csalvage] #2035230
03/20/16 07:22 PM
03/20/16 07:22 PM
Shelby, Ohio
2
Shelby, Ohio
I was able to move it straight up about 3" by cutting a section out of the upper brackets and extending the lower bracket. The hardest part was figuring out the correct angle for the adjusting slot to still work. Now I have to re-do the alternator brackets to move it about 2" toward the engine.
