correct date on alternator #2016032
02/20/16 01:42 PM
02/20/16 01:42 PM
pa
mikeporp Offline OP
mikeporp  Offline OP
pa
Would an alternator dated September of 69 with a 69 stamped in the starburst be correct for a 70 challenger.
Thanks,
Mike.
1970 challenger convertible
Re: correct date on alternator [Re: mikeporp] #2016039
02/20/16 01:49 PM
02/20/16 01:49 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Depends on the SPD of the Challenger but typically, yes.
Re: correct date on alternator [Re: mikeporp] #2016040
02/20/16 01:50 PM
02/20/16 01:50 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
When was the car built? They started production of the 70 models around July, or August of 69, so a September alt would't be right. Look at the scheduled build date of the car. Some of the other guys on here can refine this better for you.
Re: correct date on alternator [Re: mikeporp] #2016062
02/20/16 02:40 PM
02/20/16 02:40 PM
pa
mikeporp Offline OP
mikeporp  Offline OP
pa
Thanks. Don't have the build sheet. But its hard to find one, especially one with the dual pulley for a/c that I need and for $150. seems like a good price.
Re: correct date on alternator [Re: mikeporp] #2016102
02/20/16 03:41 PM
02/20/16 03:41 PM
michigan
70 buzz Offline
70 buzz  Offline
michigan
Fender tag date?
Re: correct date on alternator [Re: mikeporp] #2016118
02/20/16 04:07 PM
02/20/16 04:07 PM
pa
mikeporp Offline OP
mikeporp  Offline OP
pa
unfortunately I lost that 25 yrs ago when it was falling off so I took it off when I had the engine compartment painted. It kills e that I lost it.
Re: correct date on alternator [Re: mikeporp] #2016150
02/20/16 05:08 PM
02/20/16 05:08 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Moot point to worry about date codes then
Re: correct date on alternator [Re: ScottSmith_Harms] #2016482
02/21/16 03:59 AM
02/21/16 03:59 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
If the door sticker is still there it will have the month the car left the factory
Re: correct date on alternator [Re: Morty426] #2016586
02/21/16 01:47 PM
02/21/16 01:47 PM
70RT Offline
70RT  Offline
Mike - Most a/c equipped 1970 e-bodies left the factory ith a 3438178 numbered alternator. If you have pictures you should also see the pulley numbers "711" as the last three digits stamped into the pulley hub face. IMHO for $150 asking price, the alternator core needs to have all its original hardware and a non rusted pulley.
Re: correct date on alternator [Re: mikeporp] #2018603
02/24/16 02:59 AM
02/24/16 02:59 AM
New York, USA
Chargerfan68 Offline
New York, USA
Also, if you think you have the original K-frame in there, that date code is supposed to be very close the the completed build date of the car. It is on the front vertical surface centered usually , and has the 3 digit day followed by single year digit followed by shift. That should get you a very close indidcation of final build date.
