correct date on alternator
#2016032
02/20/16 01:42 PM
02/20/16 01:42 PM
Posts: 128 pa
mikeporp
pa
Would an alternator dated September of 69 with a 69 stamped in the starburst be correct for a 70 challenger. Thanks, Mike.
1970 challenger convertible
Re: correct date on alternator
[Re: mikeporp]
#2016062
02/20/16 02:40 PM
02/20/16 02:40 PM
Posts: 128 pa
mikeporp
pa
Thanks. Don't have the build sheet. But its hard to find one, especially one with the dual pulley for a/c that I need and for $150. seems like a good price.
[Re: mikeporp]
#2016118
02/20/16 04:07 PM
02/20/16 04:07 PM
Posts: 128 pa
mikeporp
pa
unfortunately I lost that 25 yrs ago when it was falling off so I took it off when I had the engine compartment painted. It kills e that I lost it.
[Re: Morty426]
#2016586
02/21/16 01:47 PM
02/21/16 01:47 PM
70RT
Mike - Most a/c equipped 1970 e-bodies left the factory ith a 3438178 numbered alternator. If you have pictures you should also see the pulley numbers "711" as the last three digits stamped into the pulley hub face. IMHO for $150 asking price, the alternator core needs to have all its original hardware and a non rusted pulley.
[Re: mikeporp]
#2018603
02/24/16 02:59 AM
02/24/16 02:59 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
Also, if you think you have the original K-frame in there, that date code is supposed to be very close the the completed build date of the car. It is on the front vertical surface centered usually , and has the 3 digit day followed by single year digit followed by shift. That should get you a very close indidcation of final build date.
