408 Engine Project
#201846
01/23/09 11:47 AM
01/23/09 11:47 AM
Posts: 146 Ridgeland, WI, 54763
Curt57
I have been picking up some parts for the 408 for my91 Dakota. My next pieces to by will be pistons and cam. I need some advice. This will mainly a street motor that may go to to the strip once in a while. It must burn 92 octane or lower. I want a cam that has a little lope. But not to wild. I have a set of Magnum heads. But depending on your advice,I may go with a set of EQ set up for higher lift. Heres what I have so far. 76 360 block Eagle cast 4 inch crank Scat H beam rods Crane 1.6 roller rockers,gear,pushrods Stock 318 Magnum heads[Crack free] Any advice on cam,pistons,heads,etc, will be greatly appreciated.
Re: 408 Engine Project
[Re: Curt57]
#201848
01/23/09 01:30 PM
01/23/09 01:30 PM
Posts: 20,698 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Get the magnum heads and have them ported or buy edelbrocks. If you don't get a head with decent sized valves and a good flow rate your going to be leaving a lot on the table. Your adding 50 cubes so everything including the cam needs to be upgraded to match.
Once you get the heads worked out call a cam company and let them help you. They are going to want to know the vehicle weight, stall convertor, gearing, heads, mechanical compression ratio, ect. The cam, convertor, and gearing all need to work together.
[Re: Curt57]
#201850
01/23/09 06:41 PM
01/23/09 06:41 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
i have a 360/410 stroker in a 96 Dak, i have ported cast heads(587), with a comp cam XE274H. It has a decent lobe, but not to crazy, I have hooker long tube headers, RPM air gap intake, holley 770 carb with a 904 trans.. for my CR I have 10.2 with forged flat tomp pistons, my block is decked and CNC machined.
I thnk you will like this cam.
[Re: Curt57]
#201853
01/25/09 06:25 PM
01/25/09 06:25 PM
Dakota_Don
Alton, IL
I dont know what part number the pistons are, but they are KB flat top forged .040 pistons.. www.strokerkits.com they are the ones that got everything together for me.. I am not sure abut the HP at a guess id say 435 to 440 or so.. with my mild cam what did you 408 dyno at??
[Re: Dakota_Don]
#201854
01/25/09 07:34 PM
01/25/09 07:34 PM
Posts: 12,861 Gloucester,VA STOP MOVING HERE
RangerDan440
Im running a 408 in my 96 Ram with a rotating assembly close to yours; (Cat H Beams, cast MP crank) Since mines mainly a fun street cruiser with an occasional trip to the track (13.8 in a 4400-lb truck so far) Im using cast Ross pistons and a Comp cams 210/220 .512 cam. I based my build on a package offered by KRC Performance. For street use, a mellow cam and steel heads, cast pistons should be fine.
What kind of intake are you using? Carb'd or FI?
68 Valiant 408 69 Charger 318 69 Cougar 351W 70 Torino GT 351C 71 Country Squire 351W 71 Road Runner 440+6 71 Satellite sedan 318 73 Duster 318 73 Challenger 383 77 Grand Prix 455 83 Malibu 9C1 383 84 Delta 88 403 87 Grand National 96 Ram 360 09 Crown Vic 10 Challenger R/T M6 15 Challenger Hellcat M6
[Re: 69Cuda340S]
#201858
01/16/10 04:45 PM
01/16/10 04:45 PM
Posts: 1,522 Ste-Sophie, Quebec, Canada
Wedgeman
For pistons I would go forged due to the piston speed with the 4" crank. Look at Keith Black pistons part number KB745.
Do the KB745 pistons have to be milled like the 356 with closed chamber heads ?
Dan
[Re: Wedgeman]
#201859
01/16/10 09:26 PM
01/16/10 09:26 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
745 are flat tops...no milling required.
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Wedgeman]
#201864
01/17/10 03:49 PM
01/17/10 03:49 PM
Posts: 172 Mooresville, NC
Intense RT Dan
Mooresville, NC
I assembled mine and they were .020 out of the hole by the time I got my decks squared and same height. I put them in a piston fixture and cut each piston top in a lathe to acheive .002 out of the hole. These were the kb745's with step dish. I used graph paper to do a rubbing of the step dish shape and came up with approx 1cc less dish volume as a result of cutting .015-.020 off the quench pad of the piston.
