130 tooth fly wheel
#2017748
02/22/16 11:39 PM
02/22/16 11:39 PM
Posts: 1,406 New Jersey, USA
yella71
New Jersey, USA
Is it me or do 130 tooth flywheels count 131? I counted mine 3 times both ways and came up with 131. yes its off my 340 eng .Its been in use for many years.
71 challenger convertable, 64 sport fury 383 ci with factory air
99 sebring convertable
89 CTD pup
Re: 130 tooth fly wheel
[Re: yella71]
#2017761
02/22/16 11:55 PM
02/22/16 11:55 PM
Posts: 43,285 Bend,OR USA
Cab_Burge
Are you counting the top of the teeth or the bottom of the grooves seperating the teeth?
[Re: Cab_Burge]
#2017772
02/23/16 12:03 AM
02/23/16 12:03 AM
yella71
New Jersey, USA
the teeth I'll count again
89 CTD pup
[Re: yella71]
#2018036
02/23/16 01:49 PM
02/23/16 01:49 PM
Posts: 57 North EAST
seventy
North EAST
That must be a rare one, save it may be one of a kind. I counted one in a junkyard once, came up with 139, but counted it again after marking tooth 1 and came up with 130... get one of these http://www.amazon.com/Crayola-Ultimate-C...eywords=crayola mark everytooth with a different color you should have 22 colors left in the box SSeriously though, I am going to guess your #1 tooth is also your #131
[Re: yella71]
#2018094
02/23/16 03:37 PM
02/23/16 03:37 PM
Posts: 8,341 fredericksburg,va
cudaman1969
fredericksburg,va
Lotta guts to post that, we have all done bone head things. Mark the first one, start counting the next one, count the marked one last. Everything has a procedure to follow. Had a shop teacher who had all these sayings, one poster had the 5 Ps, Proper Planing Prevents Poor Poformance. Understood it better as life went along.
[Re: cudaman1969]
#2018291
02/23/16 08:52 PM
02/23/16 08:52 PM
yella71
New Jersey, USA
nope still 131, really...I dug out another "130" tooth fly wheel and marked and counted and low and behold 130! Then I remarked the oddball and re counted. I'm tellin ya it's 131! It came off my 340 that I ran for years in the challenger, no issues. All I can think of is the ring gear was replaced at some point with a [censored] part!
89 CTD pup
[Re: yella71]
#2018372
02/23/16 10:15 PM
02/23/16 10:15 PM
dogdays
IT'S A MOPAR, NEVER SAY NEVER!!!!! The OP is absolutely correct, there was a 131 tooth wheel used on late vans. Check out Pioneer FRG-131-CH. http://www.amazon.com/Pioneer-FRG-131CH-Flywheel-Ring-Gear/dp/compatibility-chart/B0052XOHNQThis question has been asked a few times over the years and most everyone said it's a Brand X part or else you counted wrong. Neither Ford or GM V8s, at least the pushrod varieties, had any ring gears in the 130s as far as teeth go. Most started around 150 teeth. R.
[Re: yella71]
#2019112
02/24/16 10:37 PM
02/24/16 10:37 PM
cudaman1969
fredericksburg,va
, nope still 131, really...I dug out another "130" tooth fly wheel and marked and counted and low and behold 130! Then I remarked the oddball and re counted. I'm tellin ya it's 131! It came off my 340 that I ran for years in the challenger, no issues. All I can think of is the ring gear was replaced at some point with a [censored] part! Ok, cool, got to be made in metric land.
[Re: cudaman1969]
#2019164
02/24/16 11:39 PM
02/24/16 11:39 PM
Posts: 4,285 Ohio
64dodge572
Ohio
Some torqueflite 727 converters used a 131 tooth ring gear, same inside diameter as manual ring gear.
Brewers Performance Inc. 4-speed transmission and parts specialists PH 937-947-4416 or 937-698-4259 FAX 937-947-4419 www.brewersperformance.com
[Re: QuickDodge]
#2019758
02/25/16 09:01 PM
02/25/16 09:01 PM
yella71
New Jersey, USA
I'm sure it does, It was in my car for years till I pulled the motor to restore the car. Like I said a few times ran that flywheel for years no issues. I'm setting the car up with a 383 now and needed a flywheel, that's what started all this counting. Mopar just to make things difficult. Gotta love this stuff. If it was easy everybody would have one.
89 CTD pup
