Re: AIR GRABBER 1969
[Re: MidPenMopar]
#201767
01/23/09 10:47 AM
01/23/09 10:47 AM
the dash is already drilled it is below the key. someone was nice enough to post a pic here when i asked for the firewall location. it is in a prior post. it is in the moparts restoration and a12 forum.
#201768
01/23/09 02:18 PM
01/23/09 02:18 PM
Posts: 75,080 U.S.S.A.
JohnRR
U.S.S.A.
there is a dimple in the firewall , i think it's under the voltage regulator , thats were you punch the hole
[Re: MidPenMopar]
#201772
01/24/09 12:33 PM
01/24/09 12:33 PM
JohnRR
U.S.S.A.
Stu , that is NOT the correct location that the cable is supposed to exit from . the cable goes thru a 3/4" hole and has a big gromment on it similar in appearence to the gromment the speedo cable has at the firewall.
[Re: MidPenMopar]
#201774
01/24/09 02:54 PM
01/24/09 02:54 PM
this is absolutely wrong. the N96 red cable goes a tad to the left of the ash tray and the vent cable goes where your N96 cable goes.Vent cable is directly under the ignition key.
[Re: MidPenMopar]
#201775
01/24/09 02:57 PM
01/24/09 02:57 PM
switch those 2 around vent is under key. n96 cable a little to the left of the ash tray
#201776
01/24/09 03:47 PM
01/24/09 03:47 PM
JohnRR
U.S.S.A.
it's wrong on his car because the air grabber setup was more than likely ADDED to the car .
[Re: 451Mopar]
#201777
01/24/09 03:47 PM
01/24/09 03:47 PM
JohnRR
U.S.S.A.
Do you mean the RamCharger Hood? I thought the AirGrabber was a 1970-1971 option that was vacuum operated? Search the A12 section, I think there were some goos pictures of RamCharger hood cables.
no , it's called air grabber on 69 plymouths , ram charger is the dodge name
[Re: JohnRR]
#201778
01/24/09 05:23 PM
01/24/09 05:23 PM
Posts: 531 Charlotte, NC
Kowal
Charlotte, NC
Here is how the hole and cable come through the firewall. Use a stepped drill (from Sears) to cut the hole, Year One sells the gromet.
'69 Hemi Charger 500, ‘70 U code Challenger R/T (These and a bunch others at www.dkowal426.com) P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
[Re: Kowal]
#201779
01/24/09 05:24 PM
01/24/09 05:24 PM
Kowal
Charlotte, NC
Here is where you mount the cable under the dash
[Re: JohnRR]
#201780
01/25/09 07:05 PM
01/25/09 07:05 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Oh yeah, that makes sense. No wonder there's no mention of it on the fender tag.
[Re: MidPenMopar]
#201781
01/25/09 07:08 PM
01/25/09 07:08 PM
JohnRR
U.S.S.A.
correct stu , that would definitely be on the fender tag ... N96
[Re: JohnRR]
#201782
01/25/09 07:18 PM
01/25/09 07:18 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Thats it Stu, put the hood, the code police have spoken....
