Converter slip...
#2017400
02/22/16 02:56 PM
02/22/16 02:56 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
So...lets say you have a converter that calculates to 24 percent slip.
Rough guess how many mph you might gain at the stripe with say a 5 to 7 percent slip piece?
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: Converter slip...
[Re: Von]
#2017430
02/22/16 03:30 PM
02/22/16 03:30 PM
Von
NE Oklahoma
This same vert had only 4 percent slip with 4.30s and 28 inch tire. Went to 3.55s and 30 inch tire. Idk if the vert is going...or its all in the change of combo.
[Re: Von]
#2017461
02/22/16 04:01 PM
02/22/16 04:01 PM
Posts: 1,237 North Central, Indiana
Roughbird72
your gear ratio changed 18% & your tire diameter changed 7% Your rpm should be down ... a lot. How high did/does the converter stall/flash?
72 Plymouth Roadrunner 11.08@123.25
[Re: Von]
#2017485
02/22/16 04:48 PM
02/22/16 04:48 PM
Von
NE Oklahoma
I havent checked flash speed in awhile. Seems like it may be hitting a little less.
Through the lights with the 4.30/28, it was turning 6200-6300
Yest w 3.55/30s it was 5600. I knew instantly that wasnt right...
[Re: Von]
#2017555
02/22/16 06:32 PM
02/22/16 06:32 PM
Posts: 570 UK
rb446
UK
11.3@117 at your weight 4.30/28" and 515hp works out at 6100 trap rpm so you got around 100>200rpm slip in the verter. However change to a 30" tyre and 3.55's your trap rpm is showing 4750 = around 5000rpm trap, so in actual fact with the longer gear/tyre combo its not getting up to its optimum rpm near lock up stage wherever that is as fast and your spending more time with it in slip mode in 2nd/3rd....could be one explanation?
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: Von]
#2017704
02/22/16 10:28 PM
02/22/16 10:28 PM
Posts: 3,502 SOUTH JERSEY
HEMIFRED
SOUTH JERSEY
while we pay most attention to slippage at the finish it's not the most important to monitor. % numbers at 330' can be more important. Just like improvement in 60" that's where it effects ET the most.
home of the Sox and Martin Hemi Duster
[Re: Von]
#2017713
02/22/16 10:39 PM
02/22/16 10:39 PM
Posts: 52,972 Romeo MI
MR_P_BODY
All this stuff is numbers... 1/8 times will show a higher slippage than the 1/4.. you would spend more time in lower rpm which shows a greater slippage... but if your 1/8 mile and 1/4 mile show big numbers... your gonna have a conv issue... time to have it looked at... if you have 24% now.. pull it out and have it fixed.. it could be ballooning open or your folding over the fins
[Re: Von]
#2018095
02/23/16 03:41 PM
02/23/16 03:41 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Taller gear, taller tire......... Loads the converter way more, requires even more rpm to achieve an acceptable level of lock up.
Sounds like the converter just isn't set up for the taller gears and tires.
[Re: Von]
#2018117
02/23/16 04:11 PM
02/23/16 04:11 PM
Von
NE Oklahoma
Thanks for your reply Fast...I dont think there is anything wrong w the vert...its just "wrong" with the current set up.
The motor is a hair diff setup (allegedly improved vj, with before and after flow numbers, diff cam profile ) and back to my original question....how many mph am i possibly losing at the stripe due to the massive slippage?
[Re: Von]
#2018121
02/23/16 04:20 PM
02/23/16 04:20 PM
MR_P_BODY
If you know the rpm and the gear and tire height you can calculate it based on zero slippage then calculate it with the slippage ... make sure you know the tach is correct
[Re: MR_P_BODY]
#2018126
02/23/16 04:31 PM
02/23/16 04:31 PM
Von
NE Oklahoma
[quote=Von] If you know the rpm and the gear and tire height you can calculate it based on zero slippage then calculate it with the slippage ... make sure you know the tach is correct Im not following you?
[Re: Von]
#2018140
02/23/16 04:57 PM
02/23/16 04:57 PM
MR_P_BODY
There are a few on line calculators to help you figure it out if you know the stuff I said. I use to use one of the gear manufactures site for this... pretty sure it was Richmond gear.. it would give you the mph based on different slippage
[Re: Von]
#2018157
02/23/16 05:30 PM
02/23/16 05:30 PM
Von
NE Oklahoma
I may be totally confused, but im not sure how that helps me.
I would have to guess at the rpm it would cross the stripe at a lower slip vert Correct me if im wrong? Do you have a link to the calculator?
I think the answer i need is just an educated guess based on experience.
[Re: Von]
#2018309
02/23/16 09:02 PM
02/23/16 09:02 PM
fast68plymouth
So. Burlington, Vt.
Anything you come up with will really just be a (pretty much useless) WAG. For the converter to have an acceptable amount of slip with the current combo, it will just plain work differently with the motor. Different stall, different multiplication factor, different drop at the shift, etc........ All of which will affect how fast the car actually goes.
The best thing you can do if you want to see if the motor changes helped or not is to put the gears back in. Without getting the car closer to how it was before, you're just kidding yourself about what the changes may or may not have done.
If the changes to the motor are actually worth enough to matter, you should be able to pull the taller tire okay....... Provided its not way heavier than the 28's.
[Re: Von]
#2018382
02/23/16 10:25 PM
02/23/16 10:25 PM
fast68plymouth
So. Burlington, Vt.
As they say, the devil is in the details, and the important ones are missing here.
What was the ET and mph? What does it weigh? Exactly what is the converter?
As an example, if it's an 8" converter, it's going to go to about 5600 at the stripe even if it had 2.94's in it and only ran 100mph. The converter just can't lock up much below that, regardless of the gear/speed. On the other hand, if it's a stock 12" unit, it should be just about locked up solid at 4500, and if it was showing anything over about 3-4% slip with 3.55 gears at 5600rpm, I'd be checking to make sure my tac was accurate, and if it was, I'd consider the converter questionable.
Without knowing specifics, it's hard to say what's going on.
