Need some constructive feedback
#2016943
02/21/16 11:08 PM
02/21/16 11:08 PM
Posts: 16,161 Mesa, Arizona
dart4forte
Mesa, Arizona
Backing the GTS Into a parking space today and I was getting popping sound coming from the rear end. Third member is a 741 case w 3.91 and a Suregrip. It came with the the car and howls a bit. We checked the gear wear pattern and it looked good.
I was thinking it's may be several things
1. Needs more whale oil added. Clutches are making the popping sound. I need to check fluid level
2. Axle end play is off. In my mind this should only affect the wheel bearing
I should note it doesn't make a sound going forward right or left. Only backing straight, right and left.
Opinions?
Abe Lincoln
Re: Need some constructive feedback
[Re: dart4forte]
#2016983
02/21/16 11:57 PM
02/21/16 11:57 PM
RapidRobert
Needs more whale oil added. Clutches are making the popping sound. I need to check fluid level. Opinions? The PO may not have used whale oil. unless the Doc or someone advises otherwise that'd be what I'd do (cheap/easy) right off the bat
[Re: RapidRobert]
#2017012
02/22/16 12:27 AM
02/22/16 12:27 AM
dart4forte
Mesa, Arizona
Needs more whale oil added. Clutches are making the popping sound. I need to check fluid level. Opinions? The PO may not have used whale oil. unless the Doc or someone advises otherwise that'd be what I'd do (cheap/easy) right off the bat I use the term whale oil but I know it's posi additive. That's the old school speaking. Yeah, talked with several others and they say the same think. Only does it while backing.
Abe Lincoln
[Re: dart4forte]
#2017195
02/22/16 05:27 AM
02/22/16 05:27 AM
Posts: 43,285 Bend,OR USA
Cab_Burge
[Re: NANKET]
#2017268
02/22/16 11:21 AM
02/22/16 11:21 AM
dart4forte
Mesa, Arizona
This was the original pig that was put in the car. This was verified with the original owner. The car drove around all through the 70s, 80's and 90's. My guess based on conversations last night it needs some additive. I put a tube of Stalube additive in when I filled the pumpkin but that may not have been enough.
I do appriciate all the advice so far.
Abe Lincoln
[Re: dvw]
#2017696
02/22/16 10:21 PM
02/22/16 10:21 PM
dart4forte
Mesa, Arizona
How do know it's the clutches? My bet is it the cross shaft worn in the case. That's why it changes backing up, everything is loaded the opposite direction. How did you check the pattern? It can't be dead on if it howls. I say pull it, disassemble and inspect. Doug It can howl if the carrier bearing is worn.
Abe Lincoln
[Re: TJP]
#2017710
02/22/16 10:34 PM
02/22/16 10:34 PM
dart4forte
Mesa, Arizona
We have used the sta lube additive many times without issue A long shot, make sure the pinion nut is tight, Otherwise a worn differential (cone or clutches) would be my guess. The carrier was was pulled out and cleaned and powder coated. I throughly clean the inside before reassembly. When I re-filled the housing I only used one tube. That may have not been enough.
Abe Lincoln
[Re: dart4forte]
#2017732
02/22/16 11:17 PM
02/22/16 11:17 PM
Posts: 9,871 MI, usa
dvw
MI, usa
How do know it's the clutches? My bet is it the cross shaft worn in the case. That's why it changes backing up, everything is loaded the opposite direction. How did you check the pattern? It can't be dead on if it howls. I say pull it, disassemble and inspect. Doug It can howl if the carrier bearing is worn. Howl is usually the pattern, incorrect pinion depth/backlash. Bad bearings will growl. A loose set-up, (no preload) can cause howl due to the pinion or carrier moving. I can see the clutches possibly snapping but on a non worn correctly set-up sure grip this is seldom a problem. I agree clutches don't know forward from backward unless something is worn out. The two prime candidates are the cross shaft hole worn in the case. If it is a cone type the cones are worn causing contact at the outer edge of the cone. Doug
[Re: JohnRR]
#2017781
02/23/16 12:12 AM
02/23/16 12:12 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
How do know it's the clutches? My bet is it the cross shaft worn in the case. That's why it changes backing up, everything is loaded the opposite direction. How did you check the pattern? It can't be dead on if it howls. I say pull it, disassemble and inspect. Doug ^^^ This. Time to rebuild before the spider gears give out (DAMHIK).
