Re: how to wire up electronic ignition?
[Re: Mr.Yuck]
#201715
01/23/09 10:16 AM
01/23/09 10:16 AM
Posts: 1,482 Lake Orion, MI
goldduster318
Lake Orion, MI
MP sells a brand new wiring harness for the electronic ignition for $20. I highly recommend it.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
[Re: goldduster318]
#201721
01/23/09 10:07 PM
01/23/09 10:07 PM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
If you use the new mp harness, you only have to make one connection.
The other 3 leads that are used, are already premade with the proper ends. 2 for the distributor pickup, and 1 for the coil -.
The one you connect yourself is the blue wire, and it goes to 12v key on power. You're done the harness install in 5 minutes.
